viper 571xv door trigger
devildogs45
Member - Posts: 7
Posted: April 22, 2008 at 3:27 PM / IP Logged
Hello im installing a viper 571xv remote start alarm in a 2000 toyota celica and i would like to know the wire that i need to connect to the door trigger wire, so that the alarm knows when the car is open or is there another way to install this. Thank you any help would be greatly appreciated
chillin420
Copper - Posts: 236
Posted: April 22, 2008 at 4:13 PM / IP Logged
red yellow at drivers door pin and red at pass door pin...  diode isolate each and conect to neg door trigger to alarm..
you can do it....
advanced MECP, lol does it really matter....
patience is a virtue
devildogs45
Member - Posts: 7
Posted: April 22, 2008 at 5:01 PM / IP Logged
thank you yea i understand that but what wire from the alarm do i connect it to because the guide doesnt mention the door input
chillin420
Copper - Posts: 236
Posted: April 22, 2008 at 5:09 PM / IP Logged
do you have a bypass that you are installing with it also?
you can do it....
devildogs45
Member - Posts: 7
Posted: April 22, 2008 at 5:30 PM / IP Logged
no not that i know of. its just the alarm module that came in the box
devildogs45
Member - Posts: 7
Posted: April 22, 2008 at 9:01 PM / IP Logged
also is it possible to use the domelight supervision wire thought a relay to achive this. i dont have alot of experience in car alarms.
another-kelly
Silver - Posts: 618
Posted: April 22, 2008 at 10:39 PM / IP Logged
viper 571 is 2 way remote start/keyless entry only. not an alarm
devildogs45
Member - Posts: 7
Posted: April 23, 2008 at 8:52 AM / IP Logged
thank you another-kelly i didn't know that.
devildogs45
Member - Posts: 7
Posted: April 23, 2008 at 11:32 AM / IP Logged
then what sensors can i install to "fight" this
chriswallace187
Gold - Posts: 1,661
Posted: April 23, 2008 at 12:07 PM / IP Logged
It's really unclear what you're trying to fight. If you want an open door to alert your remote, it's not going to be possible with the 571. You'd need to switch the brain with whatever model Viper has the 2-way alarm/keyless/RS.
If you're under the impression that every wire you have listed for the car needs to be connected somehow, that's incorrect. All that the 571 should need to connect to are the ignition switch wires, tach, brake, parking lights, door lock/unlock, hoodpin, horn if you want it.
C Renner's Auto Electronix
