name this starter kill keypad
geis
Posted: May 13, 2008 at 8:17 AM / IP Logged
MY fiancee and I just bought a 04 350Z with what I believe to be a aftermarket starter kill. I can not find any info on it nor can I find any relay or main brain to see what type it is. We have the unlock code but I would like to find out what type it is so I can deactivate it, change the code, etc, etc.
I hope you guys have seen this before. The keypad picture is attached.
name this starter kill keypad -- posted image.
dtk1
Copper - Posts: 179
Posted: May 13, 2008 at 9:51 AM / IP Logged
its definitive after market what brand not sure may be a smart starter kill witch basically is factory starter relay out after market in but am not sure I'll check on that
geis
Posted: May 13, 2008 at 12:07 PM / IP Logged
Thanks for looking into it. I'm been searching for a month now with nothing to show for it....very aggravating.
Agree with just being a aftermarket relay kit for an already exsisiting factory system.
tedmond
Gold - Posts: 4,610
Posted: May 14, 2008 at 6:12 AM / IP Logged
that is aftermarket for sure. Do this, that keypad, pull it off since its probably held down with double side tape. on the back look for a model number or even a manufacture name. If you are willing to take apart the knee kick, there should be a brain (module) around the steering collumn area. that will have a model number for sure.
geis
Posted: May 14, 2008 at 7:48 AM / IP Logged
Alright here is the kicker. When we first got this, I did find a sticker under the center console that I thought might be linked to it. It was for a Tadiran Telematics, with some ID#'s and a date chart. After investigation online I found that this Tadiran is a battery manufacturer so I over looked it and thought that it just involves some sort of battery installed on this car.
Well, after you told me to look around the steering column I found something interesting, a module or unit with the same sticker on it. Odd isn't it?
But as far as I can research I do not see where this Tadiran is involved with security systems.
Help!
geis
Posted: May 14, 2008 at 9:05 AM / IP Logged
Found out a little more on the Tadiran:
Seen a FCC ID# and went to the FCC website to log it in to se what I could find. They had downloadable pdf's of the specs of this. Here to find out it is a vehicle location device. Still don't have a owners manual nor I know if the keypad is invovled with this.
geis
Posted: May 14, 2008 at 10:00 AM / IP Logged
Eureka!!
Update: Tadiran Telematics is a company in Israel that makes these systems. They are no longer a dealer. But I found was bought out by a parent group called Ituran, also in Israel. Buuut they have a group in Ft. Lauderdale FL (which the car came from!) called Iuran Lifetrak which specializes in vehicle location devices.
Called them and got the info and manuals I needed!
Thanks all for your help!
tedmond
Gold - Posts: 4,610
Posted: May 14, 2008 at 3:45 PM / IP Logged
hey, no problem. glad i could help.
