identify automate car alarm model
sagedm
Member - Posts: 6
Posted: May 29, 2008 at 9:33 PM / IP Logged
I just bought a 2000 Chrysler Voyager with a security alarm installed.  It has a 4-button Automate key fob remote with FCC ID EZSDEI476 and RPN476A on the back.  It has a red LED and push button installed on the dash by the steering wheel.
I just want to change the settings on this unit so I can just use the door locks and turn off the chirps.  But I need to know how to identify the model number of this system so I can re-program it.  I have tried using the Automate 552 instructions, but they do not seem to work.
techman93
Silver - Posts: 591
Posted: May 29, 2008 at 10:31 PM / IP Logged
The FCC numbers on remote won't tell you the model of the unit. You will have to take apart the van to physically see unit and read the numbers off of it.
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
sagedm
Member - Posts: 6
Posted: May 29, 2008 at 11:00 PM / IP Logged
OK.  It's apparently an AutoMate AM2 keyless entry system.  Any idea where I can find programming instructions for it?
sagedm
Member - Posts: 6
Posted: June 04, 2008 at 4:15 PM / IP Logged
Thanks for the programming instructions.  They worked perfectly.  Are there separate instructions for progamming an additional remote for this AM2 system?
