door trigger 05 impala
MikeHusain
Copper - Posts: 139
Posted: June 08, 2008 at 2:09 PM / IP Logged
I am having some trouble with an install on a 2005 impala.  Just installed the autopage rs1000 and everything works great except everytime i arm the system the door trigger goes off.  the led pattern shows that it got a door trigger, and the pager shows a door trigger.  I diode Isolated the two wires for the door inputs.  Not sure what the problem is.  The owners car has been broken into and the lock where you insert the key is punched in.  Could that cause the problem?  thanks..
dtk1
Copper - Posts: 179
Posted: June 08, 2008 at 2:28 PM / IP Logged
did you cut the factory wire and add a diode or u just tap the wire with a diode? follow this http://documents.audiovox.com/700699.pdf
