Immobilizer
Chopatoea
Posted: March 07, 2003 at 7:34 PM / IP Logged
 Is there anyone who has installed a IMB 2000 Transponder Immobilizer, manufactured by Trilogix Electronics System, that can descibe where the immobilizer wires connect to the cars electrical components relays by the numbers?
smooth db
jrilla
Gold - Posts: 1,498
Posted: March 08, 2003 at 8:05 AM / IP Logged
This is just my take on the matter: I am pretty sure i am right, but There is alaways a possibility I can be wrong.
There are three relayed outputs for three different stages. I assume that you would typically want to disable the Starter, the Ignition, and the Fuel Pump. Basicall you would find those wires and cut them and then hook up the two wires from each relay to either side of the cut wire. The manual has the wires paired so make sure that you keep them paired when you install them. What will happen is when the system is armed, the wires you cut on your car will be disconnected, and when you disarm it they will be reconnected through the internal relays.
The stage 4 output is just in case you want to disable something else, in which case you need to supply your own relay.
Everything else is pretty straight forward. The learning wire you can just leave uninstalled since you will only use it once after everything is instralled. But you may want to install the override wire on one side of a momentary switch that you would want to hide very well, just in case you lose your transponder.
feel free to email with any further questions.
J Rilla
Owner/Installer
Platinum - Posts: 12,488
What year, make & model vehicle do you have  ? Please give us more to work on and there will be someone that can help you out.
