2008 dodge chager wiring info
stevetolentino
Member - Posts: 38
Posted: July 09, 2008 at 5:10 PM / IP Logged
Installing a simple alarm in a 08 Chager, does anybody have a wiring diagram they can share?  Any problems with this vehicle?
Steve
stevetolentino
Member - Posts: 38
Posted: July 13, 2008 at 12:28 AM / IP Logged
Anybody???  Please?
Platinum - Posts: 13,726
Posted: July 13, 2008 at 7:49 AM / IP Logged
2008 dodge chager wiring info -- posted image.
2008 dodge chager wiring info -- posted image.Battery LIGHT BLUE/RED (+) IGNITION SWITCH HARNESS
2008 dodge chager wiring info -- posted image.Ignition 1 PINK/WHITE (+) IGNITION SWITCH HARNESS
2008 dodge chager wiring info -- posted image.Starter 1 YELLOW/GRAY (+) AT TIPM MODULE BEHIND RIGHT HEADLAMP UNDER HOOD 2008 dodge chager wiring info -- posted image.
2008 dodge chager wiring info -- posted image.All Door Trigger YELLOW/WHITE (+) IN HARNESS IN PASSENGER SIDE WINDSHIELD PILLAR 2008 dodge chager wiring info -- posted image.
2008 dodge chager wiring info -- posted image.LF Latch VIOLET (-) IN HARNESS IN DRIVER KICKPANEL 2008 dodge chager wiring info -- posted image.
2008 dodge chager wiring info -- posted image.RF Latch VIOLET/WHITE (-) IN HARNESS IN PASSENGER KICKPANEL 2008 dodge chager wiring info -- posted image.
2008 dodge chager wiring info -- posted image.LR Latch VIOLET/GRAY (-) IN HARNESS IN DRIVER KICKPANEL 2008 dodge chager wiring info -- posted image.
2008 dodge chager wiring info -- posted image.RR Latch VIOLET / YELLOW (-) IN HARNESS IN PASSENGER KICKPANEL 2008 dodge chager wiring info -- posted image.
2008 dodge chager wiring info -- posted image.Trunk Trigger VIOLET/ORANGE (-) IN HARNESS IN PASSENGER KICKPANEL 2008 dodge chager wiring info -- posted image.
2008 dodge chager wiring info -- posted image.Parking Lights WHITE/ VIOLET (+) IN HARNESS IN PASSENGER KICKPANEL 2008 dodge chager wiring info -- posted image.
2008 dodge chager wiring info -- posted image.Low Crr Pk Lights WHITE/ BROWN (-) AT VEHICLE HEADLIGHT SWITCH 2008 dodge chager wiring info -- posted image.
Notes    starter wire in not for remote start.  A module is needed for that.        2. To avoid domelight delay catch latch wires individually and diode isolate each wire.  3. Individual latch wires are also in harness of instrument cluster.  4. Trunk trigger also in guage harness.  5. Parking lights require the use of a 1.6K resistor.    6. Low current parking lights note is as follows  (-) THROUGH 1.6K OHM RESISTOR, MUST ISOLATE FROM SWITCH WITH RELAY
Notice that there is a polarity difference between the parking lights and the low current parking lights.
