anything i should know about 92 corvette
Escalade_on20z
Member - Posts: 24
Posted: March 08, 2003 at 7:18 PM / IP Logged
i was wanting to get as mush info as possiable on a alarm/remote start install for a 92 corvette before i take on this job. is this a hard install? is the keyless entry hard to hook-up? what does it take for the remote start? and if any one can send the wireing codes for this car .......thanks
Duston
Member - Posts: 42
Posted: March 08, 2003 at 7:26 PM / IP Logged
www.bulldogsecurity.com   try this site it has all the wire colors for installing car alarms. There are also kits you can buy there also. Good luck on the install, if you know a little about + and - inputs and outputs installing should'nt be to hard may take you about 3 hours.
Factory security systems suck!
Platinum - Posts: 12,488
Posted: March 09, 2003 at 4:32 PM / IP Logged
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
|       POWER LOCK|lt. blue            |5wi|either kick panel *1        |
|     POWER UNLOCK|black               |5wi|either kick panel *1        |
| PARKING LIGHTS +|brown               |   |headlight switch *2         |
|       HEADLIGHTS|yellow              |+  |headlight switch            |
|     DOOR TRIGGER|blk/wht, blk/yel *3 |-  |each kick panel             |
| DOME SUPERVISION|white               |-  |underdash light             |
|  TRUNK/HATCH PIN|black               |-  |switch-rear hatch           |
|TRNK/HTCH RELEASE|brown               |-  |switch in console           |
|FCTRY ALRM DISARM|lt. green           |-  |either door harness         |
|       TACHOMETER|white               |   |instrument cluster or coil  |
|      SPEED SENSE|dk GREEN / WHITE      |4  |cruise control module *4    |
|       BRAKE WIRE|white or lt.blue    |+  |brake pedal switch          |
|     HORN TRIGGER|black               |-  |steering column             |
|           WIPERS|brown, purple       |+  |wiper motor                 |
|  LF WINDOW UP/DN|dk. blu - brown     |B  |driver's door switch        |
|  RF WINDOW UP/DN|dk. blu/wht - tan   |B  |passenger door switch       |
Notes:
NOTE: This vehicle is equipped with VATS.  *1 Test from passenger door lock switch.   *2 Also found low in the drivers kick panel.  *3 Pick up both wires and diode isolate.   *4 Cruise control module is located behind passenger side of dash near radio receiver.
