2007 saturn vue, remote start
hienchink
Posted: August 21, 2008 at 6:41 PM / IP Logged
Can anyone help me and hook me up with a 2007 saturn vue remote start diagram?  Thanks in advance!!
Platinum - Posts: 13,726
Posted: August 21, 2008 at 8:27 PM / IP Logged
2007 saturn vue, remote start -- posted image.Battery ORANGE (+) IGNITION SWITCH HARNESS
2007 saturn vue, remote start -- posted image.Ignition 1 PINK (+) IGNITION SWITCH HARNESS
2007 saturn vue, remote start -- posted image.Ignition 2 BROWN (+) IGNITION SWITCH HARNESS
2007 saturn vue, remote start -- posted image.Accessory 1 ORANGE (+) IGNITION SWITCH HARNESS
2007 saturn vue, remote start -- posted image.Accessory 2 BROWN (+) IGNITION SWITCH HARNESS
2007 saturn vue, remote start -- posted image.Starter 1 YELLOW (+) IGNITION SWITCH HARNESS
2007 saturn vue, remote start -- posted image.Anti-Theft Type RESISTOR BASED SYS
2007 saturn vue, remote start -- posted image.Anti-Theft Descript PASSLOCK II
2007 saturn vue, remote start -- posted image.Key Sense LIGHT GREEN (-) COLUMN HARNESS 2007 saturn vue, remote start -- posted image.
2007 saturn vue, remote start -- posted image.Tachometer NOT PINK OR BLACK/ WHITE (AC) ANY INJECTOR
2007 saturn vue, remote start -- posted image.Speed Sense WHEEL SPEED SENSOR
2007 saturn vue, remote start -- posted image.Parking Lights BROWN (+) AT VEHICLE LIGHT SWITCH
2007 saturn vue, remote start -- posted image.Brake Lights BLUE (+) AT SWITCH ABOVE BRAKE PEDAL
2007 saturn vue, remote start -- posted image.Reverse Lights LIGHT GREEN (+) IN HARNESS AT LIGHT
2007 saturn vue, remote start -- posted image.Horn BLACK (-) STEERING COLUMN HARNESS
Key Sense is required when doing a remote start.  It keeps the check engine light from coming on.
Posted: August 22, 2008 at 12:39 AM / IP Logged
Thanks Craig, you just confirmed that these vehicles whilst looking just like European Vauxhall/Opels, even the same names (Astra) have completely different electrics. Thanks for the info. H.
hienchink
Posted: August 22, 2008 at 7:21 PM / IP Logged
I really appreciate your help!!!
chriswallace187
Gold - Posts: 1,661
Posted: August 23, 2008 at 4:19 PM / IP Logged
Actually Howie...'08 VUE probably does have the same electrics since it's roughly a rebadged Opel Antara. '07 was the last year for the old body style with plastic outer body pieces and an interior that looks like it was designed by Playskool. I know because I own one 2007 saturn vue, remote start -- posted image.
C Renner's Auto Electronix
chriswallace187
Gold - Posts: 1,661
Posted: August 23, 2008 at 4:21 PM / IP Logged
Also hienchink...if the VUE has automatic headlamps, the parking lights wire will be blue and (-) at the switch.
