roll up on alarm sound
omegamotorsprts
Member - Posts: 18
Posted: March 14, 2003 at 11:45 AM / IP Logged
Hey guys, I've put a 530t in a nissan 200sx and was wondering what you guys suggest to have it roll up when the warn away or alarm sounds. I've tried hooking up the small 200ma ground inputs from my perimeter sensor, moved it but only a little at a time(yes it was off a relay) which I thought the ground when armed only needed a ground pulse anyway to roll them up, I tried hooking up a relay to my siren output to send a ground to the GrWhArmed and it did nothing which puzzled me. DEI sent me a setup with two relays which is meant to have the horn honk on siren output but not on alarm chirp, it didn't. I'm just trying to get the windows to roll up if the perimeter sensor outputs a warn away or instant trigger. Any ideas?
camino
Copper - Posts: 54
Posted: March 14, 2003 at 8:42 PM / IP Logged
las time,i have to use a timer relay,on a code alarm,because there was no ground when arm output.so i use the lock pulse,then the same happends to me,the windows did not go up,well the diference is the 530t works with a constant ground trigger,not with pulse,well you have to make the pulse to a constant,and the way i did is with a timer relay,just adjusted it like a 10 seconds or more,it'll be enough.i use the lock pulse,you can do the same with your sensor,is the same.is not a bad idea to use a diode to prevent mal functions to the sensor because of the back feed on the relay. well if you need more help let us know.
good luck.
check double check your wire's and conection's or the fire will let you know.
