00 Prelude need help installing viper 790
rmtphan
Member - Posts: 14
Posted: March 15, 2003 at 12:35 AM / IP Logged
Hi i'm trying to install a viper 790vx alarm into and i'm having problem with three things.  One is the door trigger for it's working.  Is the wire really a WHITE/ back wire in the passanger kick panel?  Two how do I hook up a remote start for an stick shift?  I heard that i have to bypass the crutch.  How do I do that.  Third for the starter kill there are three wire a yellow and it look like it's suppose to go to the Ignition 1, a Green and it look like it's suppose to go to the ignition 2, Black wire look like it's suppose to go to the starter.  Is that correct?  Can I call up anybody if I need help.  Thank you for your time
Richard
2vmodular
Member - Posts: 46
Posted: March 15, 2003 at 1:07 AM / IP Logged
The remote start function of the 790XV is not compatible with "stick shift" vehicles as evidenced by this excerpt from the installation manual:
"IMPORTANT! This product is designed for fuel-injected, automatic transmission vehicles only. Installing it in a standard transmission vehicle is dangerous and is contrary to its intended use."
Tuesday, November 11, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
