07 dodge nitro can max 400
tj durham
Member - Posts: 8
Posted: December 22, 2008 at 10:50 PM / IP Logged
I am installing a Avital 4103 into this vehicle tommorow and am a little confused. I have used the CHDK7P2 and several others in various Chrysler vehicles my question is what about the MUX acc and start and where do the remote starters start wire hook to as these instructions are a little unclear I know the other bypasses you hooked the + start output to the bypass and it converted into the MUX wire at the ig switch
Any help wil be appreciated.
tj durham
Member - Posts: 8
Posted: December 22, 2008 at 10:59 PM / IP Logged
I read a little deeper and the - outputs from the RS go to the Pink and Violet as start and Ignition but I assume that the RS will get its Ignition input through this - wire and there is no need for any of the High current wires from the RS except 12V
tj durham
Member - Posts: 8
Posted: December 23, 2008 at 6:14 PM / IP Logged
Well I couldnt get the Can max to work properly D2D or W2W so I just did a 556U with the PK chip from the bypass 2 resistors done wasted 2 hours on tech support at Trilogic with no answers had my homeade bypass complete in 15 minutes I was only doing start anywas as vehicle will unlock with the factory key while running.
Tuesday, September 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
