2004 kia sedona door locks
shadow5978
Posted: December 27, 2008 at 7:41 PM / IP Logged
 There is probable a simple answer but heres the question.I am installing an ungo rk1 in a 2004 kia sedona. I know I connect  the neg lock to the wht/blk wire and the RED / green to the neg unlock. but there is a blue wire for second unlock. do Iconnect this to theneg unlock along with the previouse wire? Thanks for your help
calijtee1
Copper - Posts: 121
Posted: December 27, 2008 at 11:55 PM / IP Logged
the second blu is to do ulock all doors the first is to do the primary door(drivers unlock only.) depending how you want to install it. just use one .
installers do it best. we got the magic hands!
shadow5978
Posted: December 28, 2008 at 7:25 PM / IP Logged
Thank you
I wasn't sure if I used one wire or tied the two together, which didn't seem right
tedmond
Gold - Posts: 4,610
Posted: December 28, 2008 at 10:41 PM / IP Logged
you find the locks yet? if not i got a picture that will show you where it is.
btw, if you pulse the unlock wire once, it will unlock the driver door only. when you pulse it twice, it will open all doors.
shadow5978
Posted: December 29, 2008 at 7:16 PM / IP Logged
No I haven't  found my door locks yet. I thought I was going to get to work on it Sunday buthad to put something else in the shop. A picyure would be very helpfull .Thanks    My instructions says wire h4/3blue to unlock and h1/6 blue second pulse unlock so Im guesing I use h1/6 instead of h4/3.
tedmond
Gold - Posts: 4,610
Posted: December 29, 2008 at 8:44 PM / IP Logged
is door locks the only thing left on your list? of you got other missing connections. i will upload a pdf
tedmond
Gold - Posts: 4,610
Posted: December 30, 2008 at 9:01 AM / IP Logged
https://www.the12volt.com/installbay/file.asp?ID=737
ther you go. that is just a picture of the door locks. i will try to get all of them up. for some reason i can get the document to open a picture when you click on it. i will figure it out and post th ewhole doc for other users. its kinda like wiremagic, astro etc. it pinpoints the wire for oyu.
