97 nissan quest tach wire
krzysiek033
Member - Posts: 8
Posted: January 01, 2009 at 10:14 AM / IP Logged
Could anyone tell me where is tach wire located in this car. Table tells me that is at ECM, PCM or Ignition module. Can anyone tell me where are those modules located? I found 3 modles on the floor behind the center console but there is no right color wire over there.
ckeeler
Gold - Posts: 1,461
Posted: January 01, 2009 at 12:45 PM / IP Logged
the ignition module is under the hood on the engine.
krzysiek033
Member - Posts: 8
Posted: January 01, 2009 at 1:06 PM / IP Logged
I would prefer some inside the car location
ckeeler
Gold - Posts: 1,461
Posted: January 01, 2009 at 1:14 PM / IP Logged
test at the instrument cluster then.
tedmond
Gold - Posts: 4,610
Posted: January 02, 2009 at 9:22 AM / IP Logged
it would be easier to go to the engine bay. pulling out the cluster sometimes isnt the easiest route to go.
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
