remote start starts on second try
luigirox2
Member - Posts: 8
Posted: January 02, 2009 at 4:40 PM / IP Logged
Ok I have an 07 wrangler I finaly got it to work but it it seems to start on the second try  start fine with the key
Hornet 570t
I tried the tach method and it doesn't start at all
Any hl would be great thanks
thanks
ckeeler
Gold - Posts: 1,461
Posted: January 02, 2009 at 4:42 PM / IP Logged
where did you try to get tach signal from? did you test it?
ckeeler
Gold - Posts: 1,461
Posted: January 02, 2009 at 4:49 PM / IP Logged
i would use the tach method for sure, but you need to be sure you have the correct wire and the unit programmed for it to work.
luigirox2
Member - Posts: 8
Posted: January 02, 2009 at 5:26 PM / IP Logged
Well the first the engine start but quickly dies then the secondtry theengine start and stays running
thanks
ckeeler
Gold - Posts: 1,461
Posted: January 02, 2009 at 5:38 PM / IP Logged
is that with tach or voltage sensing? have you tried to increase the cranking time if you are using voltage sensing?
luigirox2
Member - Posts: 8
Posted: January 02, 2009 at 5:50 PM / IP Logged
It with the voltage setting not sure how to increase the cranking time its a hornet 570T
Thanks for the help
thanks
luigirox2
Member - Posts: 8
Posted: January 02, 2009 at 6:24 PM / IP Logged
still no luck any other sugestions
thanks
ckeeler
Gold - Posts: 1,461
Posted: January 02, 2009 at 7:54 PM / IP Logged
my only suggestion now would be to find the correct tach wire and use tach monitoring.
mike swanson
Copper - Posts: 290
Posted: January 02, 2009 at 8:21 PM / IP Logged
its the tach
the engine gets a lil build on the 1st try then its easy for it to start on the 2nd
