1994 honda civic door lock
single slam 12
Member - Posts: 10
Posted: January 06, 2009 at 10:12 AM / IP Logged
well i was wondering where would the power door lock relay be located none of the doors work i pulsed the and they do nothing  just want to know if any of you know where it could be located or what the problem could be it's a 94 civic ex 4 dr thanks
ckeeler
Gold - Posts: 1,461
Posted: January 06, 2009 at 4:17 PM / IP Logged
have you checked the fuse for the power supply to the relays?
loneranger
Copper - Posts: 572
Posted: January 06, 2009 at 4:23 PM / IP Logged
Are you saying the door locks work fine from the switches, but you can't find the wires to integrate into an alarm install?
Posted: January 06, 2009 at 4:27 PM / IP Logged
The relay unit is in the driver's door trigger colours are I can't remember but should two of these, blue, blue /black, blue/red blue/white, motor wires are WHITE/ red lock, yellow/red unlock, WHITE/ yellow power supply. At that vintage there was no motor in driver's door, just a switch.
