07 ford focus clutch bypass
07fomofocus
Posted: January 12, 2009 at 10:39 AM / IP Logged
I am installing a remote start in my manual shift '07 Focus. The remote is for a manual app. I am having trouble finding info on adding a relay for the clutch. The clutch has two switches on it ,1 that releases as you press down and the other is activated when the clutch pedal is all the way to the floor. The one that is activated when pressed all the way to the floor has 2 thin wires coming from it and I am pretty sure this is the 1 that needs the relay. If this is true can some one explain how to set up the relay. THANKS.
KarTuneMan
Platinum - Posts: 7,056
Posted: January 12, 2009 at 10:30 PM / IP Logged
Yep... them skinny little wires is the ones ya needs!
Actually it's the top one, BLACK/ red. This wire needs a negative start pulse.
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
