1997 vw jetta diesel, viper 5701
strada1972
Member - Posts: 7
Posted: January 12, 2009 at 11:08 AM / IP Logged
i'm new to forum,i want to install a viper 5701 remote starter on my vw jetta 1997 tdi that means turbodiesel,i've never installed an alarm before how hard it's the installation?it has the original alarm.thanks
Posted: January 12, 2009 at 12:26 PM / IP Logged
If this vehicle is the same as the Mk lV Golf and has a factory alarm, you will need to disable this, it cant be shutdown, assuming this also has a transponder you will need to by-pass this, pref with a 556U set to European mode.
strada1972
Member - Posts: 7
Posted: January 12, 2009 at 12:31 PM / IP Logged
no transponder only mk4 & up has that mine is a mk3
Posted: January 12, 2009 at 3:01 PM / IP Logged
Auto or manual, if manual does your alarm R/S have a manual provision?
strada1972
Member - Posts: 7
Posted: January 12, 2009 at 4:17 PM / IP Logged
manual yes the alarm has that future
strada1972
Member - Posts: 7
Posted: January 13, 2009 at 3:08 PM / IP Logged
anybody? i need help
Posted: January 13, 2009 at 3:51 PM / IP Logged
You haven't mentioned what you are installing or if you are removing the original alarm but assuming you are, here goes.
12volt+ at ign lead or battery or fuse box RED
Ign at above BLACK
2nd ignition  at above BLACK / YELLOW
Starter at above RED / BLACK
Hazards BLACK/ WHITE BLACK/ GREEN or Lights GREY/Something at fuse box (we only do hazards in Europe)
Tach back of inst panel (test behind tachometer) or DEI 454t inductive box on batt lead.
Lock GREEN+, unlock GREY + (long time since I've done one, check they're the right way round) Looms from front doors
Door contacts BROWN / WHITE at any door switch
Trunk contact BROWN / RED at light
Hood switch required, usually on a right angle bracket adjacent to battery
Reversing light Can't remember..not relevant to a manual trannie anyway
Footbrake BLACK/ RED at switch
Parking brake, switch or back of instrument panel.
Sorry, that's all I can remember, remember to give at least 5 secs wait to start, should be able to achieve that as a default on diesel setting on your R/S
strada1972
Member - Posts: 7
Posted: January 14, 2009 at 2:20 PM / IP Logged
do i need any special relay like for changing polarity?any other part thanks
strada1972
Member - Posts: 7
Posted: January 14, 2009 at 2:22 PM / IP Logged
do i have to remove the oem alarm or can i keep it there?
strada1972
Member - Posts: 7
Posted: January 16, 2009 at 12:39 PM / IP Logged
anybody else?
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
