Avital 4103 Starting on Its Own
hwater
Posted: January 14, 2009 at 8:32 PM / IP Logged
I installed an Avital 4103 on a 2003 Ford F-150 recently. It works great except it starts on its own intermittently. I dont think it is the timer feature. Anyone have any advice? thanks
Platinum - Posts: 13,726
Posted: January 14, 2009 at 10:00 PM / IP Logged
I am not at all familiar with that brand of remote start units, some units will start the vehicle every few hours when temperature goes below freezing.  It does this to help prevent freeze up.
another-kelly
Silver - Posts: 618
Posted: January 14, 2009 at 10:11 PM / IP Logged
some of the avitals have had issues with remote starting on their own (even when timer mode hasn't been started, and no temp starting). the word is that it's a freq issue with the antennas. the fix has been to program the unit for 2 pulse activation. DEI released new antennas for for some of the avitals, but rumor is the new ones aren't helping. best thing like i said earlier is to program the unit for 2 pulse activation
carbon12
Posted: January 14, 2009 at 11:54 PM / IP Logged
I suggest you check to see if the truck is starting every 3 hours or every 24 hours.
yayay
Member - Posts: 17
Posted: February 22, 2009 at 9:21 AM / IP Logged
how do you go to menu 2 to program for double pulse activation
loneranger
Copper - Posts: 572
Posted: February 22, 2009 at 1:45 PM / IP Logged
The installation manual explains the procedure.
Ideal - cmon dude, add to topics in a useful manner, not stuff that is obvious.
Story - Phzzzt! Hey, what happened?! ... Isn't it obvious?
Moral - Never dismiss the obvious.
Posted: February 23, 2009 at 6:19 PM / IP Logged
Had the same issue last year on aLondon taxi with actual alarm supposedly turning off, made the padlock button (Clifford, early G5) double pulse to arm or disarm, that cured it.
ajstetler
Copper - Posts: 94
Posted: February 24, 2009 at 11:20 PM / IP Logged
I agree with you. I have had this same problem with these units. Contact DEI for a new antenna and change programming to 2 pulses.
Big Al
