mgf fitting sheet
troublestarter
Member - Posts: 11
Posted: January 24, 2009 at 3:42 AM / IP Logged
has anyone got a vehicle fitting sheet for a 1999 mg f
many thanks
ken
Posted: January 24, 2009 at 9:28 AM / IP Logged
What do you need to know? Clue, strip the centre console.
troublestarter
Member - Posts: 11
Posted: January 24, 2009 at 12:06 PM / IP Logged
got to fit a clifford and remotestart to it
so need wiring colours and locations
Posted: January 24, 2009 at 2:06 PM / IP Logged
Do you really need these basics, are you an installer?  It's one of the simplest cars going!  The lock wires are like a Civic UK spec motor interrupt, what  DEI call 5 wire system, that unit sits under the radio, the remote fobs rather than the keys contain the transponder chips other wise I'll come along and hold your hand for £40 per hour. There is space above the glovebox for the main unit, the RS can go in the centre console. Mount the Siren to the rear in the engine bay.
Friday, March 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
