2008 gmc serria 1500, remote start
reecegr
Member - Posts: 28
Posted: January 30, 2009 at 1:18 PM / IP Logged
need a remote start dia. for 08 gmc serria,with no by passes except the passkey, don't have time to order any by passes thank you guys
Thanks in advance
another-kelly
Silver - Posts: 618
Posted: January 30, 2009 at 3:49 PM / IP Logged
from bulldog security:
12 VOLT CONSTANT        CONNECT TO BATTERY        AT BATTERY UNDER HOOD
STARTER       SEE NOTE *       SEE NOTE *
IGNITION 1       PINK (+)       IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 1       BROWN (+) or YELLOW (+)       IGNITION SWITCH HARNESS
KEYSENSE       PINK (+)       IGNITION SWITCH HARNESS
PARKING LIGHTS ( - )       LIGHT BLUE (-) SEE NOTE **       AT BCM
POWER LOCK       SEE NOTE ***
POWER UNLOCK       SEE NOTE ***
DOOR TRIGGER       SEE NOTE ****
DOMELIGHT SUPERVISION       GRAY (+) SEE NOTE **       AT BCM
HORN       TAN (-)       AT STEERING COLUMN HARNESS
TACH       NOT PINK,BROWN, OR BLACK       AT IGNITION COIL
WAIT TO START LIGHT       N/A       N/A
BRAKE       LIGHT BLUE/WHITE (+)       AT SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM        LIGHT GREEN (-)       AT DOOR MODULE INSIDE DRIVERS DOOR
ANTI-THEFT       TRANSPONDER ANTI-THEFT       TRANSPONDER @ IGNITION SWITCH TUMBLER
NOTES
NOTE * THIS VEHICLE HAS A SPECIAL IGNITION AND WILL REQUIRE A PKUGM2X FOR REMOTE START AND ANTI-THEFT.
NOTE ** THE BCM IS LOCATED TO THE LEFT OF THE STEERING COLUMN.
NOTE *** THIS VEHICLE REQUIRES A SPECIAL MODULE FOR THE DOORLOCKS. YOU WILL NEED A MODEL XK01 WITH GMDL6X 4.00 FIRMWARE.
NOTE **** THE LEFT FRONT DOOR IS GRAY/BLACK (-) AT DOOR MODULE IN DRIVERS DOOR. THE RIGHT FRONT DOOR IS TAN/WHITE (-) OR BLACK/ WHITE (-) AT PASSENGER DOOR MODULE IN PASSENGER DOOR. THE LEFT REAR DOOR IS LIGHT BLUE/BLACK (-) AT BCM. THE RIGHT REAR DOOR IS GREEN/ BLACK (-) AT BCM. USE ALL 4 WIRES AND DIODE ISOLATE EACH.
______________________________________________________________________________________
and from audiovox:
Battery          RED / WHITE          (+)          IGNITION SWITCH HARNESS LOW CURRENT, FOR HIGH CURRENT USE RED / BLACK AT VEHICLE FUSE BOX
Ignition 1          PINK          (+)          IGNITION SWITCH HARNESS
Accessory 1          BROWN          (+)          IGNITION SWITCH HARNESS MAY BE YELLOW ON SOME MODELS
Accessory 2          PINK/BLACK          (+)          IGNTION SWITCH HARNESS      FOR REMOTE START INTEGRATION
Starter 1          YELLOW/BLACK          (+)          AT MODULE UNDER HOOD BEHIND DRIVER HEADLIGHT NOT FOR REMOTE START
Starter 2          PINK/BLACK          (+)          IGNITION SWITCH HARNESS     FOR REMOTE START INTEGRATION
Anti-Theft Type          GM PASSKEY IIIŪ ANTI-THEFT SYSTEM
Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense          PINK          (+)          IGNITION SWITCH HARNESS
Tachometer          WHITE          (-)          AT IGNITION COIL
Speed Sense          YELLOW/BLACK          (AC)          AT ECM MODULE UNDER HOOD ON DRIVER FENDER BLACK PLUG PIN #57
Parking Lights          LIGHT BLUE          (-)          AT VEHICLE LIGHT SWITCH
Brake Lights          LIGHT BLUE/WHITE          (+)          AT SWITCH ABOVE BRAKE PEDAL IGNITION MUST BE ON FOR THIS WIRE TO TEST
Reverse Lights          DARK BLUE          (+)          AT BCM MODULE UNDER DRIVER DASH
Horn          TAN          (-)          IN HARNESS AT STEERING COLUMN     ALSO AT BCM MODULE UNDER DRIVER DASH
robertsc
Copper - Posts: 337
Posted: January 30, 2009 at 7:55 PM / IP Logged
this vehicle is passlock as well as passkey
reecegr
Member - Posts: 28
Posted: January 31, 2009 at 5:44 PM / IP Logged
did it this way,works great and there is not a passlock also lock and unlock wires are in by the fuse box neg.
12 VoltsRED / white (2A)+ignition harness
Second 12 VoltsRED / black (60A), RED / black (60A)+fuse box, black 40 pin plug, pins F1 and E3
Starteryellow/black (not for remote start)+ECM, black 73 pin plug, pin 52
The ECM (Engine Control Module) is on the driver side fender, behind the headlight.
Second Starterpink/black+9.6K ohmsignition harness or BCM, lt. green plug, pin 2
Ignitionpink+ignition harness or BCM, lt. green plug, pin 14
Accessorybrown or yellow+ignition harness or BCM, lt. green plug, pin 21
Second Accessorysame as second starter wire+6.3K ohms
Keysensesame as second starter wire
Data Buspink/black (resistor code), white (5V reference)muxignition harness or BCM, lt. green plug, pins 2, 4
The BCM (Body Control Module) is to the left of the steering column.
Power Lockuse interface module2008 gmc serria 1500, remote start -- posted image.2008 gmc serria 1500, remote start -- posted image.
If interface module is not available. To lock/unlock the driver door go to the driver door module or motor in the door and 5 wire the tan (lock) and purple (unlock) motor wires. To lock/unlock the passenger door go to the passenger door module or motor in the door and 5 wire the tan (lock) and gray/black (unlock) motor wires. To lock/unlock the rear doors use lt. blue (+) and white (-) at the BCM, gray plug, pins 7 and 9. The BCM (Body Control Module) is to the left of the steering column. On the base model trucks, lock is pink/black (-) and unlock is ORANGE / black (-) at the BCM, gray plug.
Power Unlocksee power lock notes2008 gmc serria 1500, remote start -- posted image.2008 gmc serria 1500, remote start -- posted image.
Parking Lights (-)lt. blue-switch or BCM, white plug, pin 8
Parking Lights (+)brown (L), brown (R)+underhood fuse box, black 30 pin plug
Factory Alarm Disarmlt. green-DDM, brown 16 pin plug, pin 4
Meter this wire while turning the key in the driver door key cylinder. The DDM (Driver Door Module) is in the driver door.
TachometerNOT pink, brown, or blackacany ignition coil or fuel injector
Brake Wirelt. blue/white+switch or BCM, brown plug, pin 6
Horn Triggertan-switch or BCM, brown plug, pin 18
robertsc
Copper - Posts: 337
Posted: January 31, 2009 at 7:54 PM / IP Logged
your pink/black wire is considered a passlock
reecegr
Member - Posts: 28
Posted: January 31, 2009 at 8:14 PM / IP Logged
All I did to he pink/blk was 9.6k to start and a 6.3 for acc. through a pos. but thank you guys for all the help.
