compustar, siren, will not arm
darvesh88
Posted: February 08, 2009 at 12:31 AM / IP Logged
Hi all,
I have a 99 Mitsubishi Eclipse GSX and this car came with a Compustar 2W900FMR. I have added a 2nd Siren into it about a couple months ago. Everything was working fine, and all of a sudden my siren's no longer at work at all. I noticed that the siren wiring got caught up in the clutch pedal and that may have damaged it. So I replaced the entire siren wiring with thicker wires and it still doesn't work. I have checked all the fuses, even disconnected the 2nd siren, but it won't chirp. So I call it a night and go to lock the car, it wont lock now either WTH. I have no idea why it would stop locking. I even tried driving the car to a stop, taking the key out of ignition so that it goes into reservation mode and locks itself no go, it just shuts off. When I go to lock the car the remote beeps indicating that something is still open (door,hood,trunk etc) I opened and re-closed everything still no go. Tomorrow I am going to disconnect the battery and let it reset itself, if it still doesn't work I have no idea what to do then. If anyone has any suggestions/thoughts that would be great.
Darvesh
james bond 007
Copper - Posts: 62
Posted: February 08, 2009 at 1:08 AM / IP Logged
sounds like you blew something, try opening the case and see if there is any internal fuse in it
loneranger
Copper - Posts: 572
Posted: February 08, 2009 at 11:07 AM / IP Logged
As james bond 007 said, you blew the transistor ouput for the siren, when it grounded.
Ideal - cmon dude, add to topics in a useful manner, not stuff that is obvious.
Story - Phzzzt! Hey, what happened?! ... Isn't it obvious?
Moral - Never dismiss the obvious.
Posted: February 08, 2009 at 1:54 PM / IP Logged
Clifford product before it was DEI was the same.  Blow that transistor and it took out locks and aux outputs.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
