how to figure out resistor needed
iteetwo
Member - Posts: 27
Posted: March 07, 2009 at 8:21 PM / IP Logged
could somebody tell me the proper way to find out what resistor you need to activate the door lock if you dont have a tech sheet.thanks
Platinum - Posts: 13,723
Posted: March 07, 2009 at 9:40 PM / IP Logged
Tell us what kind of a vehicle.
iteetwo
Member - Posts: 27
Posted: March 07, 2009 at 9:45 PM / IP Logged
its a 2006 caravan
Posted: March 07, 2009 at 10:04 PM / IP Logged
USE A 2K OHM RESISTOR TO ARM AND LOCK. DOUBLE PULSE A 5.2K OHM RESISTOR TO DISARM AND UNLOCK. MAY NEED TO USE RELAYS. SEE VEHICLE DOCUMENTS FOR REAR HATCH AUTOMATION.
I am sure that it is a typo, having the 1 wire system with 2 different pins of the same connector on the BCM.
how to figure out resistor needed -- posted image.Door Lock Circuit1 WIRE SYSTEM
how to figure out resistor needed -- posted image.Power UnlockVIOLET/GREEN(-)PIN 11 ON C3 CONN. AT BCM
how to figure out resistor needed -- posted image.PowerLockVIOLET/GREEN(-)PIN 21 ON C3 CONN. AT BCM
iteetwo
Member - Posts: 27
Posted: March 07, 2009 at 10:11 PM / IP Logged
i think you missed my point.i want to know how to figure this out without having a tech sheet to tell me which to use.thank you
Posted: March 07, 2009 at 10:26 PM / IP Logged
I thought that was what you wanted but when I asked what kind of vehicle?  I was waiting for the answer you just gave.  Since you told me what kind of vehicle you were asking about, I did the research for you.    How are you going to find the wire without the tech sheet?  If you can find the wire without the sheet, you will have to get an assortment of resistors and try them untill you get it to lock or unlock.
iteetwo
Member - Posts: 27
Posted: March 07, 2009 at 10:36 PM / IP Logged
so how does somebody figure it out besides looking at a car manual or tech sheet.thats what i want to know
ajstetler
Copper - Posts: 94
Posted: March 07, 2009 at 11:57 PM / IP Logged
Okay look, you were given bad advice about determining resistor values for locks. You don't just try a bunch until it works, that's ridiculous. This is what you have to do. If you are starting from scratch assuming you know nothing about the vehicle, go to the source. You need door locks, so go to the switch. After gaining access to the lock switch, you will need a DMM to figure out resistance, if any. In your case, first test the suspect wire for voltage. The voltage will read less than 12 volts at rest on lock and unlock, and go to ground when pressing lock or unlock. Now, figuring out the resistance- cut the lock/unlock wire in half. Test the switch side of the cut wire and set your meter to ohms. Place one lead to a good ground source and the other lead to cut side of lock wire. Press lock, that will give you resistance #1, press unlock, that will give you resistance #2. Faster than the "process of elimination" test. I hope that makes sense, that's an awful lot to type and to have it all make sense!
Big Al
chriswallace187
Gold - Posts: 1,661
Posted: March 08, 2009 at 4:27 AM / IP Logged
Or you could just unplug the switch and measure the resistance between the terminals in both positions.
C Renner's Auto Electronix
Posted: March 08, 2009 at 4:49 AM / IP Logged
Damn you Chris, beating me again that's how I found out the first time I did a Voyager!
Tuesday, October 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
