VKE 1000 Keyless Entry
1fastguy
Posted: March 23, 2003 at 10:38 AM / IP Logged
I have a VKE 1000 GM Accessories keyless entry and the resistor interface module and I need to install it into a 1999 Olds Alero. The Factory service manual only shows the wiring for the factory installed keyless entry. Does anyone have a wiring list that matches up the VKE1000 wires to the Alero Wiring. Any help would be greatly appreciated. The FCC ID on the back of the VKE1000 module is EZS249563
Also, does any one know how to program the remotes for this unit?
draasch
Gold - Posts: 2,172
Posted: March 23, 2003 at 1:55 PM / IP Logged
this the wiring info for aftermarket units, not sure if it will help or not.
Constant 12 volts RED & RED IGNITION SWITCH HARNESS
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light WHITE (-) AT COURTESY LIGHT UNDER DASH *
Trunk Pin Switch N/A
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH
Power Lock WHITE DRIVER KICK
Power Unlock SINGLE WIRE SYSTEM PANEL ** #217
* WHITE (-) Dome Light Wire Is Also Located In The Driver Kick Panel. ** Doorlocks Are Found As A Single Wire System. A Negative Pusle On The WHITE Wire In The Driver Kick Panel Will Lock The Doors. A Negative Pulse Thru A 1.5K Ohm Resistor On The Same WHITE Wire Will Unlock The Doors. #217- See Single Wire Resistor Door Lock Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
1fastguy
Posted: March 23, 2003 at 1:58 PM / IP Logged
Thanks but I also need the VKE 1000 wiring info since it didn't come with any from GM and they can seem to dig anything up
draasch
Gold - Posts: 2,172
Posted: March 23, 2003 at 6:51 PM / IP Logged
sorry i cant help you there
Good Luck
David
Ace Security
813-376-9778
Tampa
Bob1
Member - Posts: 11
Posted: March 23, 2003 at 7:30 PM / IP Logged
Okay try this. Call 1-888-4GM-VSS1 {446-8771}Monday -Friday 8am-8:30pm EST. This is GM Tech support for GM alarms and accesories. He will tell you what you need to know. Good Luck Bob
1fastguy
Posted: March 24, 2003 at 7:59 AM / IP Logged
I just called them and they can only help GM dealers and no one else. Dows anyone else have any info ? From what I am reading the 99 GrandAM is the same wiring and as the Alero if that helps. Has anyone ever installed one of these VKE1000 units?
