96 buick skylark
pitoaudiovisual
Copper - Posts: 388
Posted: May 08, 2009 at 2:15 PM / IP Logged
I have to install a remote start to a 96 Buick Skylark and was wondering if i need a bypass. I think i need a 555L but not sure. If so do i use passlock 1 or passlock 2. Thank you in advance.
Confidence is the key to any project!!
tragik
Copper - Posts: 169
Posted: May 08, 2009 at 9:52 PM / IP Logged
You wouldn't have passlock on that car. VATS maybe. Check the key. if it has a resistor in it you will have to do a bypass.
Northstart.....or start it your damn self.
pitoaudiovisual
Copper - Posts: 388
Posted: May 08, 2009 at 10:05 PM / IP Logged
What kind of bypass would I need if I need one
lucasoil4u
Copper - Posts: 317
Posted: May 11, 2009 at 1:15 PM / IP Logged
open up the sterring column. If you see three wires a yellow. black and yellow and black going to the key switch then you will need a 555l. Its pretty easy to install just takes a lil time. More than likely you will need the 555l. I had a 97achieva and a 96 grand am and they both took the 555l. open up the steering colums. 3 7mm bolts on the bottom and unscrew the tilt lever and it should come apart. Let us know what you find.
Ryan
tommy...
Gold - Posts: 1,901
Posted: May 14, 2009 at 9:07 AM / IP Logged
Have you used the application guide yet...its in the list at top of page....everything you need is there
M.E.C.P & First-Class
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
