viper 350hv siren problem
nastynate2313
Posted: July 04, 2009 at 11:05 AM / IP Logged
I hope this is the correct place to post this but I have a problem with a Viper 350HV install on a 2007 Toyota Yaris.
When I was finished connecting all the wires the last one was the 12v constant and when I connected it the siren went on and stayed on. I tried to turn the alarm of with the remote and the alarm will arm and disarm but the siren stays on. I dont know what I did wrong but can someone help.
yimke
Copper - Posts: 417
Posted: July 04, 2009 at 1:21 PM / IP Logged
Check the ground for your siren. Also measure you siren output (brown) and make sure that it is not putting out 12V constant. If it is try to manually disarm it (valet switch once with IGN forward). If all else fails I would probably say bad brain.
nastynate2313
Posted: July 05, 2009 at 12:25 PM / IP Logged
Thanks I will try that.
