Shock Sensor Placement
Liamlunchtray
Posted: March 27, 2003 at 2:50 PM / IP Logged
I have an audiovox APS610C in my car and my wife's car. They have been going off constantly. I went to adjust the sensitivity today and found that the shock sensor on my car was zip tied to a wire bundle and was able to freely move around. I called circuit city and they insisted that this was a proper way to install a shock sensor and that there is no need to securely attach it to the firewall or a structural brace. The install manual that came with the unit very clearly specifies that it must be securely fastened. Any input on this? I dont see how it could work properly if it was not affixed to something structural. Its a 2 stage sensor, so it seems to me that in order to be able to distinguish between the degrees of force it would need to be firmly attached.
Any input would be most appreciated.
Liam Gray
brianh
Silver - Posts: 518
Posted: March 27, 2003 at 5:07 PM / IP Logged
Yes the shock sensor does need to be securly attached. No offense to Circuit City workers but they are usually more concerned about the speed of the install instead of the quality. A good place to put it is on a dash support or any other structully sound location. Good luck!. Brian
bradleonard
Copper - Posts: 94
Posted: April 02, 2003 at 11:41 AM / IP Logged
Yes Circuit not only does a quick install, they often don't know what they are doing. Another good place to mount the shock sensor is on the steering column(securily). The steering column is a good location because if the car gets shaken the vibration will be transmitted through the steering column. This the best place for maximum sensitivity, with low false set offs.
Car-Stuff
Member - Posts: 26
Posted: April 02, 2003 at 2:11 PM / IP Logged
The DEI shock sensors must be mounted "cable tied" to a wiring harness and not securly fixed - otherwise they dont work very well
Nick
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
