cm5000 and 2005 ram 3500 6sp 5.9
inexplicable
Posted: August 21, 2009 at 11:53 AM / IP Logged
I hope I am not posting a duplicate. I have searched this great site but not found answers to all my questions. I am in the middle of the install so if you want pictures just ask. I am installing the compustar CM5000 starter alarm combo with the Blade AL and the ADS-TBSL C1. (I have the grey key with no built in remote.) My questions are few... for now but I want to make sure I don't F*** it up. First is the GREEN / WHITE wire 12 or 14awg says goes to the parking light positive. The only positive parking light wires that I can find are individual wires going to each side off of the fuses for each side. From what I understand this wire is to open your trunk or turn on your parking lights? Do I even need this?
The next wire is a RED / white 22awg for a door trigger input. It states the wire will test + or - only when the door is open. The only wire I could find is a violet wire going into the back of the instrument cluster. I does provide a negative trigger when the door is open but it also shows a positive output of 11v when the door is closed. It is very little amps I am sure. It will light my diode circut tester dim but not a test light. Can I still use this wire? Also the guys at the store that sold me the unit said i needed a trigger for each door. Acording to the bodybuilder schematics I have for the truck there are four seperate inputs. Do I actually need four seperate inputs?
That is all I have to ask for now. I have installed starters before but not quite like this. It is for my wifes Bday so I need to have this done by tomoorow or I am mud.
loud pipes save lives!!!
inexplicable
Posted: August 21, 2009 at 11:59 AM / IP Logged
Ok so I do have one more for now. According to the instructions for my BLADE AL the only wires I need to hook up is the Yellow analog output to the PURPLE / dark green in the drivers side kick panel and then the orange wire to the 2nd pin on the OBD 2 connector.
Sorry just want to confirm.
