2007 03/2007 hyundai sonata gl 2.4l vss
sandrelli
Member - Posts: 9
Posted: August 22, 2009 at 8:26 PM / IP Logged
Hi. I am installing a taxi meter into a 2007 Hyundai Sonata GL, and am looking for VSS sensor info to tie a taxi meter into. Any help would be greatly appreciated.. kinda stuck here. Thanks in advance.
tommy...
Gold - Posts: 1,901
Posted: August 23, 2009 at 1:17 AM / IP Logged
BatteryRED & PINK(+)IGNITION SWITCH HARNESS
2007 03/2007 hyundai sonata gl 2.4l vss -- posted image.Ignition 1BLUE(+)IGNITION SWITCH HARNESS
2007 03/2007 hyundai sonata gl 2.4l vss -- posted image.Accessory 1ORANGE(+)IGNITION SWITCH HARNESS
2007 03/2007 hyundai sonata gl 2.4l vss -- posted image.Accessory 2GREEN(+)IGNITION SWITCH HARNESS
2007 03/2007 hyundai sonata gl 2.4l vss -- posted image.Starter 1GREEN(+)IGNITION SWITCH HARNESS
2007 03/2007 hyundai sonata gl 2.4l vss -- posted image.Anti-Theft TypeUNIVERSAL IMMOBILIZER
2007 03/2007 hyundai sonata gl 2.4l vss -- posted image.Anti-Theft DescriptTHE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
2007 03/2007 hyundai sonata gl 2.4l vss -- posted image.Key SenseRED(+)IGNITION SWITCH HARNESS
2007 03/2007 hyundai sonata gl 2.4l vss -- posted image.TachometerWHITE(AC)AT PCM MODULE UNDER HOOD NEAR AIRCLEANER
2007 03/2007 hyundai sonata gl 2.4l vss -- posted image.Speed SenseYELLOW(AC)AT CONNECTOR BELOW INSTRUMENT CLUSTER
2007 03/2007 hyundai sonata gl 2.4l vss -- posted image.Parking LightsPINK(-)AT VEHICLE LIGHT SWITCH
2007 03/2007 hyundai sonata gl 2.4l vss -- posted image.Low Crr. Pk LightsPINK(-)AT VEHICLE LIGHT SWITCH
2007 03/2007 hyundai sonata gl 2.4l vss -- posted image.Brake LightsGREEN(+)AT SWITCH ABOVE BRAKE PEDAL
2007 03/2007 hyundai sonata gl 2.4l vss -- posted image.Reverse LightsBLUE(+)IN HARNESS ON DRIVER SIDE TO REAR
2007 03/2007 hyundai sonata gl 2.4l vss -- posted image.HornWHITE(-)AT BCM MODULE BEHIND CENTER CONSOLE UNDER A/C CONTROLS2007 03/2007 hyundai sonata gl 2.4l vss -- posted image.
2007 03/2007 hyundai sonata gl 2.4l vss -- posted image.Rear DefrostBLUE2007 03/2007 hyundai sonata gl 2.4l vss -- posted image.
M.E.C.P & First-Class
