93 mercury villager can not crank
johnmsi
Posted: March 29, 2003 at 10:56 PM / IP Logged
Read the forum but no listing of the information on a 93 mercury villager can not start the vehicle all the wires are correct when remote start the ignition to lights up the dash board but there is no crank on the starter. When testing with test light shows the lights to on trying to start also this vehicle is 2 wire start both need to power in order to remote start but will not crank the vehicle. Is that something missing or any bypass?
Thank in advance.
jrilla
Gold - Posts: 1,498
Posted: March 30, 2003 at 9:18 AM / IP Logged
did you use a relay for the second stater wire?   There should be about three WHITE/ Purple wires, How many did you use? If you have more than one 12v+ wire on your remote starter, you should split them up and use a couple of the White'Purple wires in the Ignition harness.
How long do the dash light turn on for? It sounded like you said that you tested the starter output from the unit with a test light and you said that it is trying to send 12 volts during cranking, but nothing happens? Explain a little more about what is happening. Make sure that all of your connections are soldered well.
ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|WHITE/ purple        |+ |ignition harness            |
|          STARTER|red                 |+ |ignition harness            |
|   SECOND STARTER|RED / green           |+ |ignition harness            |
|        IGNITION|WHITE/ red           |+ |ignition harness            |
|        ACCESSORY|WHITE/ green        |+ |ignition harness            |
| SECOND ACCESSORY|brown               |+ |ignition harness            |
|       POWER LOCK|GREEN / WHITE        |- |left kick or console        |
|     POWER UNLOCK|GREEN/ orange        |- |left kick or console        |
|       LOCK MOTOR|GREEN/ YELLOW        |   |drivers kick panel          |
|     UNLOCK MOTOR|WHITE/ green        |   |drivers kick panel          |
|    DISARM DEFEAT|WHITE/ red           |   |passengers kick panel       |
| PARKING LIGHTS +|pink               |   |left kick                   |
|       HEADLIGHTS|RED / blk, gray/red   |+ |st. column (L,R)            |
|     DOOR TRIGGER|RED / wht *1          |- |drivers kick panel          |
| TRUNK/HATCH PIN|purple or brn/wht   |- |driver kick panel           |
|        HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|                    |   |                            |
| FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
|       TACHOMETER|green               |   |ign. module on engine       |
|       BRAKE WIRE|yellow/black        |+ |brake pedal switch          |
|     HORN TRIGGER|black               |- |steering column             |
|           WIPERS|                    |   |                            |
| LF WINDOW UP/DN|blu/red - purple    |C |in drivers door             |
| RF WINDOW UP/DN|orn/blk - lt.grn/blk|C |in drivers door             |
| LR WINDOW UP/DN|RED / blu - RED / wht   |C |in drivers door             |
| RR WINDOW UP/DN|RED / blu - red       |C |in drivers door             |
Notes:
*1 Grounded at rest thru dash ind. - use diode to isolate. RED / black (-) wire in the drivers A pillar is the domelight output from timer. Gets all doors but reads delay. There is also a blue (-) in the center console that catches all doors on keyless models.
J Rilla
Owner/Installer
