2006 mercedes c230 alarm
p/t installer
Member - Posts: 29
Posted: October 04, 2009 at 9:02 PM / IP Logged
2006 mercedes c 230, i am putting a python alarm into this car and unsure where where to find the door lock/unlock wires, as well as the door pins and trunk pin wire.  i beleive i found the ignition wires coming from the smart key port . how about the domelight instead of the individual door pins? where is the domelight wire? i've heard of lots of unsuccessful attempts with mercedes vehicles, should i just stay away from this car? or is somebody sure of the wire colors and locations? or for that matter, has anyone ever put an alarm in a 2006 c 230 and had success? heeeeeeeeeeelp! thanx in advance
Platinum - Posts: 13,726
Posted: October 04, 2009 at 9:08 PM / IP Logged
2006 mercedes c230 alarm -- posted image.BatteryRED(+)IGNITION SWITCH HARNESS
2006 mercedes c230 alarm -- posted image.Ignition 1PINK/RED(+)IGNITION SWITCH HARNESS
2006 mercedes c230 alarm -- posted image.Starter 1VIOLET(+)IGNITION SWITCH HARNESS
2006 mercedes c230 alarm -- posted image.All Door Trigger2006 mercedes c230 alarm -- posted image.
2006 mercedes c230 alarm -- posted image.LF LatchBROWN / GRAY(-)IN PASSENGER DOOR SILL HARNESS
2006 mercedes c230 alarm -- posted image.RF LatchBROWN / BLUE(-)IN PASSENGER DOOR SILL HARNESS
2006 mercedes c230 alarm -- posted image.Trunk TriggerBROWN / WHITE(-)IN HARNESS FROM TRUNK
2006 mercedes c230 alarm -- posted image.Parking LightsGRAY/WHITE(+)AT VEHICLE LIGHT SWITCH
Posted: October 05, 2009 at 1:10 AM / IP Logged
Somewhere at the rear or under the rear seat is the vacuum control for the locks. You will pick up all the door/trunk and possibly hood switch there, also the lock/unlock wires. Probably blue lock and black unlock, or vice versa.  Extend lock pulse to effect window/roof close. DO NOT UNDER ANY CIRCUMSTANCES Pick up any wiring from the ignition switch before testing with a DMM. It's safer and easier to run out to an engine bay fuse box and pick these and the lights up from the fuse box/ processor outputs. Don't worry about dome supervision, the dome lights will come on with unlock. If not use driver's door lead.
Sorry I can't be more precise but I've only done audio and phone work on post 2000 models. The cost of making mistakes is too high.
