2003 honda odyssey remote start/alarm
laziebun
Member - Posts: 39
Posted: October 05, 2009 at 6:19 PM / IP Logged
I dont know why im having such a hard time with this install but its kicking my ass.
I have a 2003 Honda Odyssey EX. First problem im having is i can not find the DAMN lock and unlock wire( GREEN/ red and BLACK/ wht ) . This is what i've done to try to find it......
I took the door lock at the door panel off to make sure im looking for the right color wires, and sure enough it is. I then follow the loom from the door to the fender and then to the inside of the cab. I put one lead of the fluke to the GREEN/ red wire and then with the other lead i prob ever wire off the loom coming in from the fender and NO damn continuity AT all. I check every wire that was coming in from the driver door. Best part is i look in the loom between the door and the fender and there is no GREEN/ red or BLACK/ wht wire at all. Im lost in what to do.
Second thing is i said screw the door lock, ill do that another day. So i take the seering colum apart and there is no room for the ring off the bypass to wrap arounf the key cylinder.
Has anyone every done one that can pass some advice over this way?
flobee4
Silver - Posts: 585
Posted: October 05, 2009 at 10:41 PM / IP Logged
There are notes on the doorlocks that say if its an EX, doorlocks are at the passenger fusebox. Here is the note:
On the EX models the power lock wire is BLACK/ orange, and the power unlock wire is blue/orange. They are in a green 20 pin plug on the passenger side fuse box.
Those are probably the passenger key cylinder wires.
laziebun
Member - Posts: 39
Posted: October 06, 2009 at 6:21 AM / IP Logged
Where did you see those notes at??
flobee4
Silver - Posts: 585
Posted: October 06, 2009 at 6:48 AM / IP Logged
Here is all the info I have:
2003 Honda Odyssey     DirectWire 2.0 Vehicle Information
All Products
Item     Wire Color     Polarity     Wire Location
12 Volts     white     +     ignition harness
Starter     BLACK/ white     +     ignition harness
Ignition     BLACK / YELLOW     +     ignition harness
Second Ignition     yellow     +     ignition harness
Accessory     WHITE/ black     +     ignition harness
Power Lock     BLACK/ white     -     green 6 pin plug
The plug is located at the bottom of the fuse box. On the EX models the power lock wire is BLACK/ orange, and the power unlock wire is blue/orange. They are in a green 20 pin plug on the passenger side fuse box.
Power Unlock     GREEN/ red     -     green 6 pin plug
Parking Lights (+)     RED / black     +     10 pin plug
Hazards
Headlight     blue/red     -     headlight switch
Door Trigger     BLACK/ white     -     domelight on/off switch
Dome Supervision     lt. green     -     domelight on/off switch
Trunk/Hatch Pin     common with door trigger
Hood Pin     yellow/red     -     right of steering column
Power Sliding Door (Left)     see DirectFax document 1085
Power Sliding Door (Right)
Factory Alarm Disarm     blue     -     driver door module in door
Disarm No Unlock     see factory alarm disarm
Tachometer     blue     ac     tach test connector
The tach test connector is a 2 pin plug above the brake master cylinder.
Speed Sense     blue/white          32 pin plug @ PCM
The PCM (Powertrain Control Module) is located in the center console. The VSS is located in a 32 pin plug.
Brake Wire     WHITE/ black     +     brake pedal switch
Horn Trigger     lt. GREEN/ blue     -     steering column
Wipers     blue & blue / YELLOW     -     steering column
Left Front Window (Up/Down)     RED / blue - RED / yellow     A     driver window motor
Right Front Window (Up/Down)     blue/white - blue / YELLOW     A     RF window switch
Left Rear Window (Up/Down)     GREEN/ red - GREEN/ YELLOW     A     LR window switch
Right Rear Window (Up/Down)     RED / blue - RED / yellow     A     RR window switch
laziebun
Member - Posts: 39
Posted: October 06, 2009 at 4:35 PM / IP Logged
that is it thanks!!!
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
