engine light
gmando
Member - Posts: 16
Posted: March 31, 2003 at 4:38 PM / IP Logged
How do I stop the engine light from turning on. I installed a aps 996 from prestige in a 2003 dodge ram and now the engine light is turning on. I know it has something to do with the tach wire but I can't figure out what it is! Pleas help
cool_greg
Copper - Posts: 125
Posted: March 31, 2003 at 4:51 PM / IP Logged
the one under the hood?? or the check engine light on the dash??, does it do it when you start it with the key??
Maybe you bumped a wire or connector loose when you installed the 996?
Scott35
Silver - Posts: 258
Posted: March 31, 2003 at 5:04 PM / IP Logged
There is probably another ignition wire you need to power up.
Tacomacrew
dfiddy
Copper - Posts: 162
Posted: March 31, 2003 at 9:54 PM / IP Logged
did you power up all three ignitions? Scott35 has the right idea...
peace
jrilla
Gold - Posts: 1,498
Posted: March 31, 2003 at 10:52 PM / IP Logged
Did you install a starter kill relay?
J Rilla
Owner/Installer
Friday, February 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
