2nd ignition, 2nd accessory
christopherrice
Member - Posts: 25
Posted: October 11, 2009 at 5:43 PM / IP Logged
2004 Pontiac Grand Am Sedan / Viper 5901 RS & Alarm / iDataLink ADS-AL CA
Can anyone please help me with the 2nd ignition and 2nd accessory wires. Right now I have this setup...
Viper.................Car
Pink..................Pink
Red & RED / Black.......Red
Orange................Orange
Violet................Yellow (Starter Side)
Green.................Yellow (Key Side)
VIPER 5901
H3/1 Pink (Ignition 1 Input/Output)
H3/2 RED / White (+ 30A Fused Ignition 2/Flex Relay Input 87)
H3/3 Orange (Accessory Output)
H3/4 Violet (Starter Output)
H3/5 Green (Starter Input)
H3/6 Red (+ 30A Fused Ignition Relay Input)
H3/7 Pink/White (+ Ignition 2 Flex Relay Output)
H3/8 Pink/Black (87a Of Ignition 2 Flex Relay)
H3/9 RED / Black (+ 30A Fused Accessory/Starter Relay Input)
ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|red |+ |ignition harness *1 |
| STARTER|yellow |+ |ignition harness *1 |
| IGNITION|pink |+ |ignition harness *1 |
| SECOND IGNITION|dk. green |+ |ignition harness *1 |
| ACCESSORY|orange |+ |ignition harness *1 |
| SECOND ACCESSORY|brown |+ |ignition harness *1 |
Platinum - Posts: 13,726
Posted: October 11, 2009 at 6:20 PM / IP Logged
2nd ignition, 2nd accessory -- posted image.BatteryRED(+)IGNITION SWITCH HARNESS
2nd ignition, 2nd accessory -- posted image.Ignition 1PINK(+)IGNITION SWITCH HARNESS
2nd ignition, 2nd accessory -- posted image.Ignition 2GREEN(+)IGNITION SWITCH HARNESS
2nd ignition, 2nd accessory -- posted image.Accessory 1ORANGE(+)IGNITION SWITCH HARNESS
2nd ignition, 2nd accessory -- posted image.Starter 1YELLOW(+)IGNITION SWITCH HARNESS
christopherrice
Member - Posts: 25
Posted: October 11, 2009 at 7:01 PM / IP Logged
So what wires need to be use on the RS for ignition 2?
*H3/2 RED / White (+ 30A Fused Ignition 2/Flex Relay Input 87)
*H3/7 Pink/White (+ Ignition 2 Flex Relay Output)
*H3/8 Pink/Black (87a Of Ignition 2 Flex Relay)
Is H3/2 ran to a 12v Constant and H3/7 ran to the ignition 2 (green) on the ignition harness? Or is H3/1 split?
Posted: October 11, 2009 at 7:19 PM / IP Logged
From what I am reading, the above line is correct.
dismay
Member - Posts: 19
Posted: October 12, 2009 at 2:05 AM / IP Logged
I have exactly the same questions as the original poster, except on my 01 Yukon, only thing different is my 2nd ignition wire is white instead of green.
Is it correct to connect both the red and RED / white viper wires to the vehicle red constant?
The real question is how is the 2nd ignition wire supposed to be powered?
a. just connect it to the pink veh wire along with the pink viper wire?
b. power the 2nd ignition wire using the onboard flex relay: connect the pink to pink(veh), the red and RED / white to the red(veh), the green and violet to yellow(veh), and the pink/white to the 2nd ignition wire(veh, green for op, white for me)
c. none of the above.
What exactly triggers the continuity of the flex relay? power at Ignition 1?(pink)
Thanks in advance for any help!
dismay
Member - Posts: 19
Posted: October 12, 2009 at 2:24 AM / IP Logged
Whoops forgot, what about this wire? does it need to be powered? By the description, does this feed the power to the starter, and to the orange accessory wire?
christopherrice
Member - Posts: 25
Posted: October 12, 2009 at 5:58 PM / IP Logged
H3/1 Pink (Ignition 1 Input/Output) - Pink on the ignition harness
H3/2 RED / White (+ 30A Fused Ignition 2/Flex Relay Input 87) -12v Constant (Red on vehicle)
H3/3 Orange (Accessory Output) - Orange on vehicle
H3/4 Violet (Starter Output) - Starter car side
H3/5 Green (Starter Input) - Starter key side
H3/6 Red (+ 30A Fused Ignition Relay Input) - 12v constant (red on vehicle)
H3/7 Pink/White (+ Ignition 2 Flex Relay Output) - 2nd Accessory (White on yours, green on mine)
*H3/8 Pink/Black (87a Of Ignition 2 Flex Relay) - Not used
H3/9 RED / Black (+ 30A Fused Accessory/Starter Relay Input) - 12v constant
Yes H3/9 does need to be hooked up. Powers your accessory wire and starter relay.
