hummer h3 2008
masterito
Member - Posts: 9
Posted: October 12, 2009 at 7:14 AM / IP Logged
Sorry for my English I'm from Russia. Where can I connect to a wire speed sensor Hummer H3 2008.
fcss
Copper - Posts: 92
Posted: October 12, 2009 at 1:34 PM / IP Logged
GREEN / WHITE Wire located at the ECM at the passengers side firewall closest to the fender well.  Im not sure if it will be them same for that car in russia
hope it is correct
masterito
Member - Posts: 9
Posted: October 13, 2009 at 3:26 AM / IP Logged
Thanks I will try.
masterito
Member - Posts: 9
Posted: October 13, 2009 at 3:35 AM / IP Logged
Another question how to connect a car alarm to start the ignition
Platinum - Posts: 13,726
Posted: October 13, 2009 at 4:58 AM / IP Logged
hummer h3 2008 -- posted image.BatteryWHITE/ BLACK(+)IGNITION SWITCH HARNESShummer h3 2008 -- posted image.
hummer h3 2008 -- posted image.Ignition 1WHITE/ GREEN(+)IGNITION SWITCH HARNESShummer h3 2008 -- posted image.
hummer h3 2008 -- posted image.Accessory 1WHITE/ RED(+)IGNITION SWITCH HARNESShummer h3 2008 -- posted image.
hummer h3 2008 -- posted image.Anti-Theft TypeGM PASSLOCK II® ANTI-THEFT SYSTEM
hummer h3 2008 -- posted image.Anti-Theft DescriptTHE BCM MODULE MUST SEE A SPECIFIC RESISTANCE VALUE BEFORE THE VEHICLE WILL START PROPERLY
hummer h3 2008 -- posted image.TachometerBROWN / WHITE(AC)AT PCM MODULE ON PASSENGER SIDE OF FIREWALL UNDER HOODhummer h3 2008 -- posted image.
hummer h3 2008 -- posted image.Speed SenseDARK GREEN / WHITE(AC)AT PCM MODULE ON PASSENGER SIDE OF FIREWALL UNDER HOODhummer h3 2008 -- posted image.
hummer h3 2008 -- posted image.Parking LightsBROWN / WHITE(-)AT VEHICLE LIGHT SWITCH HARNESS
hummer h3 2008 -- posted image.Brake LightsLIGHT BLUE(+)AT SWITCH ABOVE PEDAL
hummer h3 2008 -- posted image.Reverse LightsLIGHT GREEN(+)AT UNDERHOOD FUSEBOX
hummer h3 2008 -- posted image.HornBLACK(-)AT BCM MODULE IN PASSENGER KICKPANELhummer h3 2008 -- posted image.
hummer h3 2008 -- posted image.Anti Theft RXWHITE/ BLUE(+)IGNITION SWITCH HARNESS
hummer h3 2008 -- posted image.Anti Theft TXWHITE/ YELLOW(+)IGNITION SWITCH HARNESS
hummer h3 2008 -- posted image.Rear DefrostWHITE
Posted: October 13, 2009 at 5:05 AM / IP Logged
Battery may also be Orange
Ignition may also be Dark Blue
Accessory may also be Brown
masterito
Member - Posts: 9
Posted: October 13, 2009 at 5:11 AM / IP Logged
Thank you. How to avoid GM PASSLOCK II ® ANTI-THEFT SYSTEM
