need wire colors for a 2003 bmw 745 li
stevetolentino
Member - Posts: 38
Posted: October 22, 2009 at 6:08 PM / IP Logged
Does ANYBODY have wire color & location info sheets?  I need it by late tonight or first thing in the morning.  I really appreciate it.
Stevet
t&t tech
Platinum - Posts: 2,621
Posted: October 22, 2009 at 10:03 PM / IP Logged
Last time you argued with one of the few guys who might know! Maybe if he's in a good mood he might help you! If not! Well, good luck!
stevetolentino
Member - Posts: 38
Posted: October 23, 2009 at 10:43 AM / IP Logged
I never argued with him I was stating why I did what I was doing, and why in the heck would you bring that up to begin with?  If you have nothing to ad to this in terms of being constructive to my question here what are you trying to start?  Be best you leave your thoughts to yourself,  seems like your tring to create dirt that isn't there to the surface just for your own kicks?  An on a public forum, thanks buddy!
Posted: October 23, 2009 at 11:21 AM / IP Logged
Sorry guys haven't a clue, try Avox or Directwire. My guess is everything will be similar to the 5 series, i.e. lock and total close wires in the door at the switch, light GREEN/ grey, pos at 5amps for the trunk release and surprise surprise, 2x red or RED / green or RED / blue at the ignition, light green for ignition, GREEN/ black for starter and violet for ACC or second ignition if remote start.  Tach will be a thin black on the OBD2 socket, can't help you with lights, we use indicators, door contacts, RED / blue pos at lamp under dash, hood possibly BROWN / green at hood switch, trunk WHITE/ brown. Diode the pos side of the trunk lights. You really ought to find these things out for yourself.
metz35
Copper - Posts: 458
Posted: October 23, 2009 at 2:32 PM / IP Logged
i couldnt find athing on this car via audiovox or wiremagic.....will a 740 do?
t&t tech
Posted: October 23, 2009 at 5:06 PM / IP Logged
I humbly apologise mr stevetolentinto! I was wrong to bring that up!
Good luck on acquiring the info you need!
stevetolentino
Member - Posts: 38
Posted: October 23, 2009 at 7:25 PM / IP Logged
Apology accepted, I do look through all resources on some vehicles especially the hard ones.  If I can't find it, it would mean others can't either.  So, that's why I ask here because it would be archieved into this database so others can find it.
Thanks guys for trying, it's time to ask the dealer techs.
