2003 camry 4cyl transponder bypass
any_available
Member - Posts: 16
Posted: October 28, 2009 at 2:27 PM / IP Logged
hi to all,
trying to install a remote starter on 2003 camry. i have pkht from codealram as bypass module but does not work. car remote starts with key in ignition. any help????
wiring according to diagram is all ok
thanks
syl20rochon
Copper - Posts: 298
Posted: October 29, 2009 at 6:31 PM / IP Logged
Did the bypass programmed as per instructions?
Sylvain Rochon
MECP security specialist
Tech support for remote starters
26 Years of experience counts
I'm here to help.
syl20rochon
Copper - Posts: 298
Posted: October 29, 2009 at 6:35 PM / IP Logged
I tried to find the pkth manual on the web...no luck...do you have a link?
Sylvain Rochon
I'm here to help.
any_available
Member - Posts: 16
Posted: October 30, 2009 at 1:58 PM / IP Logged
sorry my mistake... it's hpkt i am following the procedure correctly as we well without luck
chriswallace187
Gold - Posts: 1,661
Posted: October 31, 2009 at 6:14 PM / IP Logged
@ syl20rochon,
It's a rebadged Bypasskit piece (the PKT). Manual's here.
@ any_available,
Are you getting the feedback from the keysense buzzer and the security light that the manual tells you to expect?
C Renner's Auto Electronix
