1992 GM 1500 alarm/keyless entry
RicksUnlimited
Posted: April 02, 2003 at 8:40 AM / IP Logged
I am having problems with the lock/unlock feature on the alarm. When wired to the diagram it disables the interior lock and unlock buttons and will only unlock the passenger side door. It will not unlock the drivers side door at all but it looks as if the pulse hits but the lock will not respond. Is there a special wiring diagram for these type vehicles? If I disconnect the alarm and you hit the interior lock/unlock button it works just fine. Help..... If you have a wiring diagram for this type vehicle please post it and i will compare. Thanks in advance.
RicksUnlimited Electronics
securinu
Silver - Posts: 772
Posted: April 02, 2003 at 10:54 AM / IP Logged
Which diagram diagram did you use? also what colors wires are cut/taped and where are they cut/taped.?
also what model Gm and 2 or 4 door???
Joe O'Byrne
Owner / Installer
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
