2005 dodge stratus remote starter
slobalt
Posted: December 08, 2009 at 11:57 AM / IP Logged
I purchased a commando EZ-2500 remote starter w/keyless entry for my mom's 2005 dodge stratus sedan. im looking for a wiring diagram and was also wondering if there were any t harnesses available so i dont need to splice directly into the vehicles wires. also wondering if there is any other information i need.
ceasar326
Copper - Posts: 239
Posted: December 08, 2009 at 1:31 PM / IP Logged
STRATUS SEDAN  2001 -2006
 KEY T-HARNESS IMMOBILIZER
  CHRY KEY-1   CHR-2   TRANSPONDER, REQUIRES 791 BYPASS and EXTRA IGNITION KEY (Some Vehicles)
 PART  COLOR LOCATION
 12 VOLT CONSTANT  PINK/BLACK (+)   IGNITION SWITCH HARNESS
 STARTER YELLOW (+)  IGNITION SWITCH HARNESS
 STARTER 2 N/A
 IGNITION 1 BLUE (+) IGNITION SWITCH HARNESS
 IGNITION 2 GREEN/ RED (+) 20 Gauge wire, 1 of 2, use the one that tests as Ignition IGNITION SWITCH HARNESS
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 BLACK/ ORANGE (+)  IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2 BLACK/ WHITE (+) or BLACK/ BLUE (+) (Normally not used)  IGNITION SWITCH HARNESS
 KEYSENSE N/A
 PARKING LIGHTS ( - ) N/A
 PARKING LIGHTS ( + ) BLACK / YELLOW (+)  IN DRIVERS KICK PANEL
 POWER LOCK WHITE/ DARK GREEN (1-Wire Door Lock System) See NOTE *1  @ BCM, Connector C4 Pin 15, See NOTE *3
 POWER UNLOCK Same wire, See DIAGRAM   See DIAGRAM
 DOOR TRIGGER See NOTE *2  @ BCM, See NOTE *3
 DOMELIGHT SUPERVISION YELLOW (-), Requires Part #775 Relay  @ FRONT of FUSEBOX, 6-Pin Plug
 TRUNK RELEASE BLACK/ WHITE (5-Wire) See NOTE *5, Requires Part #775 Relay  @ BCM, Connector C4, Pin 1, See NOTE *3
 SLIDING POWER DOOR N/A
 HORN BLACK/ RED (-)  @ STEERING COLUMN HARNESS
 TACH ANY wire NOT GREEN/ LIGHT GREEN  @ COIL PACK
 WAIT TO START LIGHT N/A
 BRAKE WHITE/ TAN (+)  @ SWITCH ABOVE BRAKE PEDAL
 FACTORY ALARM DISARM  LIGHT GREEN/ ORANGE (+) See NOTE *4  @ BCM, Connector C4, Pin 4, See NOTE *3
 ANTI-THEFT CHRYSLER'S SENTRY KEY (GRAY KEY ONLY) A TRANSPONDER SYSTEM  TRANSPONDER @ IGNITION SWITCH TUMBLER
 EXTRA INFORMATION
 NOTE *1 this vehicle uses a 1-Wire Door Locking System, the LOCK requires a (+)Positive thru a 620 Ohm Resistor and the UNLOCK requires a (+)Positive thru a 2700 Ohm Resistor, some units will also require 2 extra relays Part #775, to connect, See DIAGRAM NOTE *2 the DRIVERS DOOR is a TAN (-) Pin 5 the PASSENGER DOOR is a TAN/RED (-) Pin 6 the DRIVERS REAR DOOR is a TAN/ORANGE (-) Pin 7 and the PASSENGER REAR DOOR is a TAN / YELLOW (-) Pin 8 when connecting to an ALARM SYSTEM use all 4 DOOR TRIGGER wires and DIODE ISOLATE. to connect, See DAIGRAM NOTE *3 the BCM (Body Control Module) is attached to FUSE/RELAY BOX located under the drivers side of the dash NOTE *4 the FACTORY DISARM wire requires a (+)Positive thru a 750 ohm Resistor and an extra relay part #775, to connect, See DIAGRAM NOTE *5 the TRUNK RELEASE System on this vehicle is a 5-Wire Type and will require an extra Relay part #775, to connect, See DIAGRAM.
