wiring sirens to relay
colin12
Member - Posts: 16
Posted: December 19, 2009 at 5:21 AM / IP Logged
Hey,
I currently have a car alarm that has a 12v out put for the siren i want to hook up 3 sirens(which i already have) i was told the best way was to connect everything to a relay because it will provide more constant power. If this is correct could someone plaese tell me what pins to connect on the relay i have read the guide on relays and still have no idea how to do it.
tedmond
Gold - Posts: 4,610
Posted: December 19, 2009 at 6:17 AM / IP Logged
85 - ground
86 - 12v siren input from alarm/rs
87 - constant 12v fused @ 10 amps
30 - to positive sirens
Platinum - Posts: 13,725
Posted: December 19, 2009 at 6:58 AM / IP Logged
If you need a picture, The wire labeled Remote Turn On Lead is the positive siren output of your alarm.  Your new sirens are labeled fans in the picture.
wiring sirens to relay -- posted image.
colin12
Member - Posts: 16
Posted: December 19, 2009 at 3:17 PM / IP Logged
Awesome exactly what i was looking for thank you very much got everything hooked up and its working great
Friday, January 30, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
