2001 crown vic rear defrost
nessus
Posted: December 28, 2009 at 4:43 PM / IP Logged
Hi I have an 2001 Crown Vic ex police car and had a Viper 5901 installed by the dealer. The dealer did not install the trunk release (the form here helped me find the correct wire and the wiring for the relay) and the defrost. I live in Canada and would like the defrost to work. Can someone help me with the wire color and its location and if a relay is need? Also if the wire needs to be cut?
Thanks in advance
Nessus
t&t tech
Platinum - Posts: 2,622
Posted: December 28, 2009 at 6:03 PM / IP Logged
TRNK/HTCH RELEASE|purple / YELLOW       |5wi|drivers door harness
Says five wire so you need a single pole double throw relay wired like this
Pin87 and 86- twelve volts fused at ten amps
Pin 85-  To the negative trigger from alarm
Pin 87@ - Cut the purple / YELLOW and connect the side from the switch here
Pin 30 - To the side of the wire that goes to the solenoid.
nessus
Posted: December 28, 2009 at 6:20 PM / IP Logged
That works perfect. Do you know how to do the defrost?
Nessus
t&t tech
Posted: December 28, 2009 at 8:46 PM / IP Logged
What do you mean how? I just described it above, the negative trigger is the blue/white status out from the starter!
Platinum - Posts: 13,726
Posted: December 28, 2009 at 9:03 PM / IP Logged
I think he is asking for a wire color for the defrost wire.
chadwa2003
Copper - Posts: 353
Posted: December 28, 2009 at 10:41 PM / IP Logged
it is blue/orange at the switch no relay required -1 sec pulse needed to turn defrost on
nessus
Posted: December 30, 2009 at 11:23 AM / IP Logged
Thanks that worked. This is a great help.
Nessus
