looking for python 991 manual
desertrage
Member - Posts: 7
Posted: December 30, 2009 at 12:35 AM / IP Logged
Does anyone have a Python 991 installation manual? Also what is the correct DEI immobilizer bypass kit?
Thanks Guys!
desertrage
Member - Posts: 7
Posted: December 30, 2009 at 12:51 AM / IP Logged
I forgot to mention the immobilizer is for a 2000 Acura Integra.
desertrage
Member - Posts: 7
Posted: December 30, 2009 at 12:57 AM / IP Logged
Sorry for all the questions, I am finishing up the install and have a few thing left.
Will I need to use a relay for the negitive trigger on the domelight? The alarm lists the BLACK/ white wire as 200ma max. I check it with a volt meter and it reads 370ma. This should answer my question, but I have been told that it is not nessesary since its a -12?
hurleyloser
Copper - Posts: 157
Posted: December 30, 2009 at 1:35 AM / IP Logged
PKALL for bypass, use a relay for your domelight activation to avoid damage to the Python if you're meter over 200mA.
MECP Master Certified Technician
ASE A6 Certified Technician
dcorwin822
Member - Posts: 34
Posted: December 30, 2009 at 6:28 AM / IP Logged
download the torrent. extract the python directory and search for 5702P thats what the 991 is called in DEI's eyes 991 is it's name for the customer.
N5702P_2008_08web_small.pdf is the install guide
G5702P 2008-08web_small.pdf is the owners guide
QR5702 2008-08web.pdf is the quick refrence sheet.
desertrage
Member - Posts: 7
Posted: December 30, 2009 at 10:28 AM / IP Logged
Thanks guys!
I was able to find those PDF files. Why does DEI use different p/n's for the installer and the customer? I was getting frusturated looking for a 991 manual.
hal900020
Posted: November 27, 2010 at 7:51 PM / IP Logged
 I'm also looking for an installation manual for a python 991. I tried downloading the torrent that was mentioned but,,no luck. If anyone knows where I can get a manual that would be a lifesaver.thank you,Harold
hal9000
Platinum - Posts: 7,828
Posted: November 27, 2010 at 8:15 PM / IP Logged
hal900020
Posted: November 29, 2010 at 7:04 PM / IP Logged
thanks for the info. It worked. I have an 09 Ford Escape,but I can only get the manual for an 07. Does anyone know if the wiring is the same for these two cars? thank you.
hal9000
Posted: November 29, 2010 at 7:17 PM / IP Logged
Bulldog Security shows them as very different.  Bulldog Security WEB site  :  http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
