2002 land rover discover ii se
magicone2571
Member - Posts: 9
Posted: January 12, 2010 at 4:41 PM / IP Logged
Just curious if anyone has any info on a 2002 Land Rover Discover II SE. I've never done one and I had someone call about it. I can't find nothing on google or bypass kit. Thanks.
shaip99
Copper - Posts: 112
Posted: January 13, 2010 at 1:01 AM / IP Logged
i did one over the summer i wish i wrote down wire colors but its not that hard of a vehicle nothing really special just take your time on it
all your ignitions wires are at the tumbler
the lock wires are in the center console at the lock switch (- trigger)the center console just unclips
you will need to lose a key for bypass
the vehicle will disarm with remote start ignition and transponder
park lights are at the switch + trigger
brake is at the brake
tach is at the injector
they seem worse than they are
"Computer games don't affect kids, I mean if Pac Man affected us as kids, we'd
all run around in a darkened room munching pills and listening to repetitive
music."-Kristian Wilson, Nintendo Inc.
monty_77
Copper - Posts: 491
Posted: January 14, 2010 at 9:15 AM / IP Logged
Land Rover Discovery 2002
WIRE      COLOR LOCATION        POL.
Battery 1 Brown Ignition Harness Positive
Ignition 1 Yellow Ignition Harness Positive
Ignition 2 White Ignition Harness Positive
Starter 1 WHITE/ Red Ignition Harness Positive
Accessory 1 Lt.GREEN / WHITE Ignition Harness Positive
Parklights Positive Red 4 wire plug at Steering Column Positive
Brake Lights GREEN/ Purple At Brake Switch (Above Brake Pedal) Positive
Horn PURPLE / Orange Security Module (3) Negative
Tach (6) At ECM Under Passenger Side Dash 2 Cyl.
E-Brake Pink/Orange At Parking Brake Switch or Cluster Negative
OEM Hood Switch PURPLE / Orange At Hood Switch Negative
Disarm Blue/Green or Blue/Gray (5) At Security Module (3) Negative
Rearming Blue/Green or Blue/Gray (5) At Security Module (3) Negative
Dome Sensor Pl/Wht & Pl/Grn (2) At Security Module (3) Negative
KeySense WHITE/ Purple Ignition Harness Positive
Door Pin FL PURPLE / White At Security Module (3) Negative
Door Pin RL PURPLE / Lt-Green At Security Module (3) Negative
Door Pin FR PURPLE / Lt-Green At Security Module (3) Negative
Door Pin RR PURPLE / Lt-Green At Security Module (3) Negative
TailGate Pin PURPLE / Lt-Green At Security Module (3) Negative
Comments :
Note :This vehicle is equiped with a immobilizer system that needs to be bypassed,( transponder )
(1) Behind drivers side headlight.
(2) PURPLE / Green is for the drivers door and PURPLE / White is for the 3 passengers doors. Use both and diode isolate each.
(3) The factory security module located under the passenger side of the dash to the far right behind a panel. Held into place with two
7 mm bolts.
(4) Both wires need to be powered.
(5) Same wire. Pulse with lock to arm, and pulse with unlock to disarm.
(6) The tach wires are WHITE/ Blue Pin 7, Blue Pin 2, Red Pin 8 or Pink/Black Pin 7. Use either one and set the Astrostart for 2 Cyl.
The ECM is under the Passenger Side Dash and these tach wires are in a 5 wires connector.
