prostart 2005 ford ranger not starting
metzen
Posted: January 19, 2010 at 11:33 PM / IP Logged
Hello,
Sorry for the newb post but I'm trying to figure out why we can't get this remote start to work. I've searched for answers and suspect I might be on to something but need some reassurances.
I have a 2005 Ford Ranger (manual transmission) and a ProStart 3370 (doesn't really exist per Google apparently). It's pretty much the exact same as the 3371 except for the "yellow loop" and it doesn't work with automatic transmissions.
Anyways, I've connected all the wires according to the wire diagrams I've found here and from autostart.ca. I've managed to flash the hood-pin, program the remote, set the multi-speed tach, and set the unit to ready mode. But the car will not remote start. The lights will come on for a couple of seconds then turn off. The fuel pump does NOT start.
From the autostart.ca website it says the car has a transponder security system and has diagrams to bypass it, but I'm not sure the truck actually has this system. From the autostart website it says the transponder wires are located here:
prostart 2005 ford ranger not starting -- posted image.
Well, on this truck it does not have this device or any of those wires. The green plug in the picture just does not exist.
With that, am I missing the security system? Is this is missing piece that's preventing this truck from starting remotely?
tedmond
Gold - Posts: 4,610
Posted: January 20, 2010 at 6:26 AM / IP Logged
you need a bypass module.
place one of the keys in the igition cylinder, try to remote start it. If it starts its a bypass issue. Look on your dash and notice THEFT or SECURITY.
i did a ford ranger about a week ago. The green plug was not there, but it was grey in colour. it will be in the same location.
Ground - pin 1
Ignition - pin 2
data -  (refer to bypass manual)
Ted
Compustar Expert
metzen
Posted: January 20, 2010 at 8:48 AM / IP Logged
"you need a bypass module.
Ground - pin 1
Ignition - pin 2
data - (refer to bypass manual)"
Placing a key in the ignition cylinder and trying to remote start results in the same. Lights come on for about 4 seconds then off.
Any recommendations on a bypass module?
Thanks!
tedmond
Gold - Posts: 4,610
Posted: January 20, 2010 at 8:34 PM / IP Logged
i think you missed the start wire. Does the unit have any diagnostics (park light flashes)
there are many to choose from. i use the Fortin modules. the can sl2 will do the job, but all bypasses for this truck requires 2 ORIGINAL keys to program.
Ted
Compustar Expert
metzen
Posted: January 21, 2010 at 11:10 AM / IP Logged
Thanks Tedmond.
I've double/triple checked the start wire via a multimeter to ensure there was connectivity. My friend suggested the same thing.
Purple Starter Wire to RED / Blue wire
Without a transponder bypass, what would the remote start do?
moonliter
Copper - Posts: 322
Posted: January 21, 2010 at 12:28 PM / IP Logged
This is a manual tranny, so you need to hook up the clutch bypass, door triggers & e-brake. You never mentioned anything about the clutch so that could be your problem. Get the remote start part working first then do the transponder bypass. Open up the steering upper shroud, if the ignition switch has a plastic ring around it, then you need a bypass module.
metzen
Posted: January 23, 2010 at 9:02 AM / IP Logged
Sorry, I should have mentioned, the clutch bypass is done, connected door triggers and parking-brake.
How do you get the remote start part working first without a transponder bypass? Leave the key in the ignition? Does it need to be turned to anything or just sit there?
moonliter
Copper - Posts: 322
Posted: January 23, 2010 at 9:27 AM / IP Logged
Just leave the key in and leave it in OFF position instead of pulling the key out when you get the ready mode set. After you get out of the truck, shut the truck down with remote, now try to remote start. If it starts & stays running then you know the remote part is working. after that, proceed to work on your pats bypass.
remember roll down the window when you leave the key inside !
Thursday, August 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
