dei tech sheet for a 09 maxima sv
mascache
Posted: February 10, 2010 at 11:20 AM / IP Logged
im working on installing remote starter on a 09 Nissan Maxima SV with the pushbutton starter and smartkey info on interfacing with the pushbutton starter and also any other tips will be appreciated.
thanks,
Mascache
Chris Luongo
Platinum - Posts: 3,746
Posted: February 10, 2010 at 1:20 PM / IP Logged
Don't know what "SV" means.
What remote starter and what bypass do you plan to use? Both Fortin (ifar.ca) and ADS (idatalink.com) have install guides specifically for this car you can find on their respective sites.
Pretty much all the push-to-start Nissans are the same, wiring-wise. Any previous posts here about any of these cars should contain many useful tips for you. The 2007-up Altima is the most popular model....search for old posts about the Altima.
mascache
Posted: February 10, 2010 at 2:11 PM / IP Logged
SV the fully loaded model.  As the starter & car alarm I'm Installing is the Autopage C3-RS-915 LCD and the Bypass I purchased was from Idatalink model number ADS-DLSL CA 2. I will look into the 2007 Altima SmartKey/Push Starter wiring, Thanks for the help. But I would like to get it for the 2009 Maxima SmartKey/Push Starter wiring to make sure If anyone could help I would really appreciate it.
Thanks,
Mascache
