pkdock
monty_77
Copper - Posts: 491
Posted: February 10, 2010 at 12:34 PM / IP Logged
has anyone used pkdock what do you think of them?
or is is just a relay in a box for 8-20 dollars
Can you just use the dei rf rings with a relay or do they need some type of current traveling through them to make them work
more or less is it a passive antenna or an active one
tommy...
Gold - Posts: 1,901
Posted: February 10, 2010 at 1:23 PM / IP Logged
Not sure if you have seen this... http://documents.audiovox.com/700665.pdf ...Have not seen the pkdock
M.E.C.P & First-Class
monty_77
Copper - Posts: 491
Posted: February 10, 2010 at 1:29 PM / IP Logged
yes i have seen that just wondering if you can do that with the rf loops you buy with the transponder on them.
i think you should be able to do that
i have a couple of dodge people that don't want to give up a key for a one button RS
and i have a couple of the RFLCHGM and if i can save 7 to 19 dollar just using a relay that's what i will do
tommy...
Gold - Posts: 1,901
Posted: February 10, 2010 at 6:34 PM / IP Logged
could always do a blank un-cut key and program...Or the 1 key required  for programming by-passes(i freakin love these things...dunno...dodges/chryslers always gave me a little h@ll trying to do the 2 key programming)...But im assuming the cheapest route is what your looking for(ie...one button starters)...I get ya know...Just using the loop w/ transponder (not sure how i didnt pick up on that)...Hmmmm...Ive only used them in combination with the bypass...Do you order these separate or are just not using the rest of the stuff...?
