04 chrysler sebring convertible touring
terryokey
Posted: March 10, 2010 at 2:21 AM / IP Logged
Can anyone tell me the Alarm /keyless Entry is it the same wiring system for the sedan and convertable? as it does not state in the wiring section
tommy...
Gold - Posts: 1,901
Posted: March 10, 2010 at 8:10 AM / IP Logged
Battery PINK/BLACK (+) IGNITION SWITCH HARNESS
04 chrysler sebring convertible touring -- posted image. Ignition 1 DARK BLUE (+) IGNITION SWITCH HARNESS
04 chrysler sebring convertible touring -- posted image. Ignition 2 GREEN/ RED (+) IGNITION SWITCH HARNESS
04 chrysler sebring convertible touring -- posted image. Ignition 3 BLACK/ WHITE (+) IGNITION SWITCH HARNESS
04 chrysler sebring convertible touring -- posted image. Accessory 1 BLACK/ ORANGE (+) IGNITION SWITCH HARNESS
04 chrysler sebring convertible touring -- posted image. Starter 1 YELLOW (+) IGNITION SWITCH HARNESS
04 chrysler sebring convertible touring -- posted image. Anti-Theft Type SENTRY-KEY
04 chrysler sebring convertible touring -- posted image. Anti-Theft Descript AN RF SIGNAL ACTIVATED SYSTEM
04 chrysler sebring convertible touring -- posted image. Key Sense LIGHT BLUE (-) IGNITION SWITCH HARNESS
04 chrysler sebring convertible touring -- posted image. Neutral Safety BLACK/ LIGHT BLUE (-) IN HARNESS TO TRANSMISSION
04 chrysler sebring convertible touring -- posted image. Tachometer BLACK/ GRAY (AC) AT IGNITION COIL
04 chrysler sebring convertible touring -- posted image. Speed Sense LIGHT GREEN / WHITE (AC) AT THE PCM IN A 38 PIN CONNECTOR PIN 32 04 chrysler sebring convertible touring -- posted image.
04 chrysler sebring convertible touring -- posted image. Parking Lights BLACK / YELLOW (+) LOCATED ON THE BACK OF THE FUSE BOX
04 chrysler sebring convertible touring -- posted image. Brake Lights WHITE/ TAN (+) AT VEHICLE FUSE PANEL
04 chrysler sebring convertible touring -- posted image. Reverse Lights VIOLET/BLACK (+) IN HARNESS IN DRIVERS KICKPANEL
04 chrysler sebring convertible touring -- posted image. Horn BLACK/ RED (-) AT STEERING COLUMN HARNESS
Remote Start wiring............................^
Alarm and Doorlocks.........................
04 chrysler sebring convertible touring -- posted image. All Door Trigger GREEN/ YELLOW (-) 19 PIN PLUG DRIVERS SIDE DASH...LOCATED IN A BLACK 19 PIN PLUG ON THE BACK OF THE FUSE BOX UNDER THE DRIVERS SIDE DASH 04 chrysler sebring convertible touring -- posted image.
04 chrysler sebring convertible touring -- posted image. Domelight Super GREEN/ ORANGE
04 chrysler sebring convertible touring -- posted image. LF Latch TAN (-) LOCATED AT THE BOTTOM OF THE FUSE BOX
04 chrysler sebring convertible touring -- posted image. RF Latch TAN/RED (-) LOCATED AT THE BOTTOM OF THE FUSE BOX
04 chrysler sebring convertible touring -- posted image. Trunk Trigger TAN/BLACK (-) LOCATED AT THE BOTTOM OF THE FUSE BOX
04 chrysler sebring convertible touring -- posted image. Alarm Disarm LIGHT GREEN/ ORANGE (-) LOCATED AT THE BOTTOM OF THE FUSE BOX DISARM IS POSITIVE TRIGGER THRU A 750 OHM RESISTOR. MUST USE RELAYS. ...THESE ARE THE DOOR KEY CYLINDER WIRES. METER THE WIRES WHILE TURNING THE KEY IN THE DRIVER DOOR. THIS WILL ALSO UNLOCK THE DOORS WITH A DOUBLE PULSE 04 chrysler sebring convertible touring -- posted image.
04 chrysler sebring convertible touring -- posted image. Alarm Arm LIGHT GREEN/ ORANGE (-) LOCATED AT THE BOTTOM OF THE FUSE BOX ARM IS POSITIVE TRIGGER THRU A 1.8K OHM RESISTOR. MUST USE RELAYS. ... 04 chrysler sebring convertible touring -- posted image.
Power Unlock WHITE/ LIGHT GREEN (+) LOCATED AT THE BOTTOM OF THE FUSE BOX...Pin 15... 04 chrysler sebring convertible touring -- posted image.
04 chrysler sebring convertible touring -- posted image. PowerLock WHITE/ LIGHT GREEN (+) LOCATED AT THE BOTTOM OF THE FUSE BOX
M.E.C.P & First-Class
tommy...
Gold - Posts: 1,901
Posted: March 10, 2010 at 8:12 AM / IP Logged
This is the convertible...Didnt check to see if it is the same...Probably for the most part...?!  Here is the diagram for doorlocks... http://documents.audiovox.com/700651.pdf
terryokey
Posted: March 10, 2010 at 12:19 PM / IP Logged
 Tommy Thank you for the information, I've been after this since last September .
Mike M2
Platinum - Posts: 2,652
Posted: March 10, 2010 at 4:56 PM / IP Logged
Sedan and convertables are the same, coupes are different....
Mike M2
Tech Manager
CS Dealer Services
