alarm goes off sometimes
not_startin
Member - Posts: 31
Posted: April 11, 2010 at 1:50 AM / IP Logged
I have an '03 Ram diesel. My remote start is a prostart w/ Xpress bypass that I put in over a year ago. As of a couple days ago, when I remote start the truck it kicks the security. It blasts the factory alarm (which I can turn off with the 'unlock') and then cranks but won't start. It works flawlessly with the keys, and the remote start issue only happens sometimes. Any suggestions? Or is the problem as simple a a bad bypass (but why would it only happen sometimes)?
If it ain't broke...Maybe it should be!
not_startin
Member - Posts: 31
Posted: April 14, 2010 at 12:48 PM / IP Logged
OK...anyone have any idea's? Is it possible that it could be a 3rd party frequency causing the transponder to not work right, tripping the factory alarm?
Thack79
Silver - Posts: 526
Posted: April 14, 2010 at 1:07 PM / IP Logged
is the bypass just for the transponder only or is it a full door lock/security/transponder bypass?
not_startin
Member - Posts: 31
Posted: April 14, 2010 at 4:08 PM / IP Logged
just the transponder.
Chris Luongo
Platinum - Posts: 3,746
Posted: April 14, 2010 at 6:45 PM / IP Logged
I've seen that on a Caravan before.
As you've discovered, if a Chrysler product sees someone trying to start it without a valid transponder, the factory alarm goes off.
Really hard to say if you have a bad relay in the bypass module, an intermittent connection from your remote starter, or what.
But the most likely thing if I had to guess would be that the ring around the key cylinder has come out of place or shifted around somehow.
I would go back to your ring, and try shifting it around and just kind of generally neatening it up a little, and see what you get.
not_startin
Member - Posts: 31
Posted: April 14, 2010 at 11:31 PM / IP Logged
cool.I'll give that a try.
not_startin
Member - Posts: 31
Posted: April 18, 2010 at 3:29 PM / IP Logged
Well I checked the ring. Looks OK or at least the same as before. Two wraps around...I even went in and "relearned" the bypass to the ECM. I'll give it a try and see if that cures it....I sort of doubt it will since I didn't really do anything. I am wondering if there is any possible chance that my tailights could cause it? I bought a set of LED tail lights and it seams that only occasionally they will flash when I open the interior door. Not too sure what thats all about but maybe if the remote start park light flash was back feeding that could have something to do with it? I guess if what I tried already doesn't fix it then I will put the stock lights back in and try that.
not_startin
Member - Posts: 31
Posted: April 22, 2010 at 9:45 PM / IP Logged
Well so far, so good. I guess relearning the bypass to the ECM worked. Haven't had a problem in a few days...
