sunroof
Jose12
Posted: April 12, 2003 at 10:45 PM / IP Logged
I have an 1984 toyota cressida and I would like my sunroof to close when I arm the alarm. I already installed a roll-up window module to make the sunroof close but it won't work. Is there any other way to make it work? Thank You.
cpgoose
Gold - Posts: 1,098
Posted: April 14, 2003 at 1:07 PM / IP Logged
Well, I'm not really sure what you did, but wouldn't you need to use a module like the DEI 529t, and then hook it up to your alarm's ground-when-armed output? Then, when you arm the car, the window will shut until the unit sees the spike, and will stop?
