viper 5901 in 2002 accord
dontstealme
Member - Posts: 24
Posted: April 13, 2010 at 12:40 AM / IP Logged
I've done several electronic hook ups, turbo timers, engine management systems, but this is my first alarm. I've been learning a lot and enjoying the install. I am almost finished and wanted to confirm everything is connected correctly. I would greatly appreciate it.
Here is what I have.
Viper 5901 with 556UW bypass module. 2002 Accord Keyless Power windows/Locks without factory alarm. Automatic.
I only posted the ones I'm not 100% sure about.
H1 HARNESS
H1/4 WHITE/ Brown Parking Isolation Wire (87a Onboard Relay)-> Not using.
H1/6 Violet (+) Door Trigger Input -> Not using since doors are - polarity
H1/8 Green (-) Door Trigger Input-> Using since doors are - polarity correct?
H1/9 BLACK/ White 200mA Dome Light Supervision Output_> Using door trigger and relay.
H1/10 WHITE/ Blue Remote Start/Turbo Timer Activation Output-> Not using
H1/11 White Parking Light Output-> Done
H1/12_Orange 500mA Ground When Armed Output -> Not used
H2 HARNESS
H2/1__GREEN/ Black_____200mA OEM Alarm Disarm Output -> Not used
H2/2__ORANGE / Black____200mA Aux 4 Output-> Not used
H2/3__GREEN / WHITE_____200mA OEM Alarm Arm Output-> Not used
H2/4__Violet/Black_____200mA Aux 2 Output -> Not used
H2/5__WHITE/ Black_____200mA Aux 3 Output-> Not used
H2/6__WHITE/ Violet_____200mA Aux 1 Output-> Not used
H2/7__
H2/8__
H2/9__
H2/10_Dark Blue _200mA Status Output -> To 556UW
H2/11_Pink/White______200mA Flex Relay Control Output -> Not used
H2/12_Orange_________200mA Accessory Output-> Not used
H2/13_Purple__________200mA Starter Output-> Not used
H2/14_Pink _200mA Ignition 1 Output-> Not used
H2/15_
H2/16_
H2/17_
H2/18_
H3 HARNESS
H3/1 Pink Ignition 1 Input/Output-> Done to igntion wire
H3/2__RED / White Flex Relay Input-> Not used
H3/3__Orange Accessory Output -> Done
H3/4__Violet Starter Output (Car Side)->Done
H3/5 Green Starter Input (Key Side)->Done
H3/6 Red Ignition 1 Input-> Constant 12V
H3/7__Pink/White______(30) Flex Relay Output -> Not used
H3/8__Pink/Black______(87a) Flex Relay Input-> NOt used
H3/9__RED / Black_______Accessory/Starter Relay Input-> 12v constant
Here is the viper 5901 PDF manual
http://www.directeddealers.com/manuals/IG/Viper/N5702V_2008_08web.pdf
Here is the 02 Accord wiring diagram I used
02 Accord Wiring Diagram Viper 5901 VIper manual Viper Manual I only posted the ones I'm not 100% sure about.
dontstealme
Member - Posts: 24
Posted: April 13, 2010 at 11:58 AM / IP Logged
Can someone help me out I'm working on this right now and need the car.
