Help, need a new Antenna!
enforcerviper
Member - Posts: 26
Posted: April 13, 2003 at 7:45 AM / IP Logged
I've got a Delta DA Combo Alarm and the antenna has quit working.  Ever since I got my varad scanner installed it's been giving me trouble.  Usually if I move the little box (not the brain, but the antenna itself) it will start working again.  However this time no luck.
Does anybody know where I can get a replacement antenna?  I will order from wherever as long as they ship to Canada.
I've checked continuity in all 3 wire leads and it seems good, so I know it must be the little circuit board at the end of the antenna.  Funny thing is that the installer who installed the alarm combo more than 2 years ago had the same problem.  However back then he just grabbed a new antenna and everything worked.
If I can't get a new antenna I guess I'll have to replace the whole system.  It should be easy enough since all the wirng is already done.
enforcerviper
Member - Posts: 26
Posted: April 13, 2003 at 7:46 AM / IP Logged
Oh yeah I checked the circuit board inside the antenna and everything looks normal. Nothing burned or broken solder.
enforcerviper
Member - Posts: 26
Posted: April 13, 2003 at 10:27 AM / IP Logged
Allright, I put everything back together and mounted it back on the winshield.  Now everything works again.  Something inside the antenna must be loose but I can't figure out what cause everything looks good.
Fireman__1
Member - Posts: 11
Posted: April 13, 2003 at 10:18 PM / IP Logged
should check inside your antenna for cold solder joints.
Joshua Hickey
enforcerviper
Member - Posts: 26
Posted: April 13, 2003 at 10:44 PM / IP Logged
thanks, just did that.. to the naked eye I couldn't see anything unordinary.. but with a magnifier I found that there was a resistor which had a cracked solder.  Fixed it now.. good stuff.  thanks
Fireman__1
Member - Posts: 11
Posted: April 13, 2003 at 10:52 PM / IP Logged
your welcome, i find for most circuit boards in vehicles they tend to get cold solder joints because of the hot and cold temperatures that they're consistantly exposed to.
Joshua Hickey
Monday, March 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
